oil changes
Old Jul 18, 2004 | 12:14 AM
ramfan5.9's Avatar
ramfan5.9
Default oil changes
when my dad has the oil changed on the truck he brings it to a garage that changes oil but they also grease stuff under the truck what do they grease and what do they use thanx
Old Jul 18, 2004 | 10:21 AM
dustyloins's Avatar
dustyloins
Hall of Fame Member
Default RE: oil changes
They lube the grease fittings with a "grease gun". Most modern cars have factory sealed fittings that don't require lube.....
Old Jul 18, 2004 | 12:01 PM
moparturd's Avatar
moparturd
Alot of times too they will lube/spray the bushing on the sway bars and control arms along with the body isolators.
They may also be lubing the universal joints on the driveshaft.
Old Jul 18, 2004 | 12:56 PM
ramfan5.9's Avatar
ramfan5.9
aite thanx guys
Old Jul 18, 2004 | 02:11 PM
Fiddle Player's Avatar
Fiddle Player
Yeah that's it! I couldn't get the words outta my head to say it.. I knew they lubed the grease fittings...I should remember because I change my own oil...I love the feeling of oil running down my arm..especially when it's room tempurature[sm=smiley36.gif][sm=smiley36.gif]
Karen
Old Jul 18, 2004 | 08:15 PM
charlie1935's Avatar
charlie1935
It feels real good when you drain the oil immediately after an hour or two on the road.
Old Jul 18, 2004 | 08:25 PM
dustyloins's Avatar
dustyloins
Hall of Fame Member
You drain your oil when its room temp?
Old Jul 23, 2004 | 04:03 PM
Fiddle Player
When I change it, it's usally slightly warm..seems to drain out quicker and better I thought..but I must say it does feel good running down my arm [sm=smiley36.gif][sm=smiley36.gif]
Karen
Old Jul 23, 2004 | 08:04 PM
dustyloins's Avatar
dustyloins
Hall of Fame Member
Yeah, you want it warm, it gets more of the the old/bad oil out, along with the dirt/shavings....
