BoostController question!?
Old Apr 10, 2007 | 08:42 PM
Kristjan SRT4's Avatar
Kristjan SRT4
Default BoostController question!?
Hi guys, and girls.
I was thinking about buying a BoostController for my car. I'm not going to buy stage 2 or 3 or anything but I want some extra power. What should I get beside from the boostcontroller...
* New WGA? Perhaps AGP?
* Walbro 255L Pump?
* Something else?
* And how high could I boost it safely?
Thanks in advance for great replies because I know you always give them U'r the best!
P.s. My car usually holds around 14-15psi and 14 to redline.. Goes occationally to 17psi on high oct and in cold weather
Old Apr 10, 2007 | 09:22 PM
Plan B's Avatar
Plan B
Default RE: BoostController question!?
WGA's compliment bc's quite nicely. AGP or PTP are two that I have heard nothing but good things for. I don't think a fuel pump is necessary on the stock turbo setup. I have cranked the boost on mine to spike at 18 (bc) and hold around 16-17 (wga) and I have more than enough fuel. Oh yeah, a wideband would be a good idea too since you are starting to play with the A/F ratios. If anything you will need a fuel management system to CUT fuel and lean it out a little. That is why you don't need the fuel pump. Then of course items to maintain traction and prevent whell hop. Wider rims/tires, solid motor mounts, etc. You already have at least stg. 1, correct? That is another good thing to have... I'm sure people will add to this list...
Old Apr 11, 2007 | 05:05 AM
PSI Chick's Avatar
PSI Chick
^^^^ x2
Old Apr 11, 2007 | 05:28 PM
Kristjan SRT4
Thanks Plan B for this advice, so which fuel system should I get? Are there many types?
Old Apr 11, 2007 | 06:31 PM
Plan B's Avatar
Plan B
No prob! I'm just happy i am at the point where I have advice to give! I've been really looking at the DTEC FC lately. It has everything I am looking for at this point.... And the interface is a gameboy advance sp! How tight is that!
Old Apr 12, 2007 | 04:09 AM
PSI Chick's Avatar
PSI Chick
if you want a really nice fuel set up the arronneon return line kit, 255 pump, s2 injectors and a dtec fc will do wonders
Old Apr 12, 2007 | 11:36 AM
Kristjan SRT4
Sry, but what is a dtec fc :s hahhaha
Old Apr 12, 2007 | 12:02 PM
redevil's Avatar
redevil
its a fuel computer, one of the best for the money.But you can also buy it with a boost controller, kinda like a combo you know.Works great, I've never heard a complaint.Check it out at turboxs.com....you can find them cheaper...theres other stores and you might even find used ones for a good price....hope this helps
