Spring change-out VS Coil-over install.
Old Sep 14, 2004 | 01:15 PM
ToughLove's Avatar
ToughLove
Default Spring change-out VS Coil-over install.
I am trying to decide if it would be better just to change out the springs or pay the big bucks for the coil-over install (Mopar Stage 2 or 3). I do not plan on doing any kind of track racing, so I am thinking that the coil-overs would be a bit overkill. My main intent is to lower the car some and to improve the handling. I know that I will sacrifice adjustibility by not going with the coil-overs, but if I can get a set of springs with a decent rate (not too stiff - not too soft), that would suit me just fine.
This may be a "loaded" question but what would be a good set of springs to put on this car, that would lower it about 1.5 inches and would improve the handling?
Dave
2004 SRT-4 (E. Blue)
Old Sep 15, 2004 | 01:01 AM
byebye's Avatar
byebye
Default RE: Spring change-out VS Coil-over install.
I have the stage 2 and wish I bought the stage 3. If that's all you want than most springs will do.
Old Sep 21, 2004 | 06:34 AM
Barneydriver's Avatar
Barneydriver
tein makes a great spring specifically designed for the srt-4.
Old Sep 21, 2004 | 01:41 PM
badsrt4's Avatar
badsrt4
whats the difference between the stages??
Old Sep 21, 2004 | 08:04 PM
Barneydriver
stage 1 is the springs, stage 2 is coilovers w/ height (damping) adj, stage 3 is coilovers w/ height (damping) and rebound adj.
see http://www.mopar.com/StreetCatalog.pdf
Old Sep 22, 2004 | 03:39 AM
Undertaker's Avatar
Undertaker
just installed my Teins this weekend. Pretty good. Car bounces a lot more. Can feel more bumps in the road. But not bad overall. Handling is a bit better. It will be lots better with some 5-way adjustable struts which will be a future item.
Steve
Old Sep 22, 2004 | 04:04 AM
Barneydriver
do you have the h or s techs?
Old Sep 22, 2004 | 03:56 PM
Undertaker's Avatar
Undertaker
I got the S-Techs. Got them for $125. Should have went with the H's since they are more stiff, but I can get use to it.
Old Sep 23, 2004 | 04:17 AM
Barneydriver
yeah, i'm pretty impressed w/ the htechs. i had eibachs on for a little while, but i didn't really like them- i had them on my neon, and they were awesome, but quite a few people don't like them on the srt.
Old Sep 25, 2004 | 03:06 PM
gipfiddle2's Avatar
gipfiddle2
Had goldlines on my 02 pt cruiser w/adj. KONI's VERY STIFF VERYBOUNCY.This time it will be coilovers or nothing. 04 red srt-4 sunroof STOCK........REALLLY?
