COLD AIR INTAKE....???
Old Sep 19, 2004 | 06:06 AM
  #21
badsrt4's Avatar
badsrt4
Default RE: COLD AIR INTAKE....???
i might just go with k&n im not only looking for performance but i also want some looks, and by the way 71RoadRuner's looks that might just be it. how does the k&n sound. i've heard soem intakes that sounds like a turbo spooling up. sounds great, so i was just wondering if that was the case with the k&n..
Old Sep 19, 2004 | 08:43 AM
  #22
71RoadRunner's Avatar
71RoadRunner
The K & N sounds great! At an idle it sounds quite just like stock. With light throttle when you let off the gas you hear the turbo flutter which sounds kinda like a rattle snake. Under moderate throttle you hear the spooling of the turbo quite nicely, but under heavy to WOT you hear the turbo scream loudly, it sounds like a train whistle! Oh how I love my K & N. As far as I have read, it looks like the K & N Typhoon gives the largest power gains. I would love to see someplace test all available CAI's to see which truely is the best, but what is the best on a stock motor is most likely not the best on a well modified motor and the same applies in reverse.
Old Sep 19, 2004 | 07:07 PM
  #23
millenniumdna's Avatar
millenniumdna
Roach where did you get the ingen cai? Im looking for one.
Old Sep 19, 2004 | 07:59 PM
  #24
roachnigga's Avatar
roachnigga
turboneonstore.com
Old Sep 20, 2004 | 06:31 PM
  #25
posthondaremoval's Avatar
posthondaremoval
"see posthondaremoval, you have a short ram from aem... the aem cai is what does damage. the extension tube hits the hood. so there is a difference thats why when i said cai i ment cai not ram. "
my bad, gump - guess I'd better read a little more carefully.
Sorry to hear the CAI has fitment issues.
Old Sep 21, 2004 | 04:47 AM
  #26
Barneydriver's Avatar
Barneydriver
modernperformance tells me that the iceman puts out a couple more horses than the k&n, presumably b/c the plastic does not heat soak like the metal on the k&n does, and the routing is supposed to be straighter (according to mp). i think i've decided on the k&n though, it just looks so much better, plus i can put a heat wrap on it if i'm really worried about a couple degrees.
Old Sep 21, 2004 | 09:20 AM
  #27
71RoadRunner
I would hope so, the Iceman is the ugliest thing I've ever seen. Even the stock set up looks like a show peice in comparison.[:'(][:'(][:'(]
Old Sep 21, 2004 | 09:24 AM
  #28
drtelco's Avatar
drtelco
Volant makes a nice looking CAI. Not sure if they make for all applications...
Old Sep 21, 2004 | 08:01 PM
  #29
Barneydriver
well, now psichick has convinced me to look at the psi-fi piece, the srt-flo intake- it seems like a good one, although, again, not nearly as attractive as the k&n, but it looks like it performs better. now i'm back where i started...[&o]
Old Sep 21, 2004 | 09:12 PM
  #30
badsrt4's Avatar
badsrt4
whats the psi-fi piece?????[sm=dontgetit.gif][sm=dontgetit.gif][sm=dontgetit.gif], its that a brand or something, sorry if you guyz already explained this [>:][>:] but im nosey, lol...
