Oil Catch Can: Its Purpose.
Old Oct 19, 2004 | 03:59 PM
  #31
SRT_YA's Avatar
SRT_YA
Default RE: Oil Catch Can: Its Purpose.
I believe the others will verify, but it won't hurt anything to add another one... Roadrunner and I believe Roach both have two on their cars (possibly others as well... I can't remember what everone has done to their cars )
Old Oct 19, 2004 | 06:11 PM
  #32
dustyloins's Avatar
dustyloins
Hall of Fame Member
Yeah, many of the folks here who have CAIs have added a second OCC. Otherwise, a 2nd one is not really needed...
Old Oct 20, 2004 | 06:00 AM
  #33
71RoadRunner's Avatar
71RoadRunner
Yeah, it's only something you want to get if you have a CAI or a short ram. You can either get a second OCC or you can run it into your existing OCC with a Y adapter and simply plug off the opening on the CAI tube. I went with a second OCC to see exacly how much oil is lost from each hose. If you run a second OCC you will begin to wonder about it, because it doesn't loose nearly as much oil as the PCV hose and it may take a few weeks before you even notice any starting to accumulate in the second OCC. But believe me, it will eventually start collecting it.
Old Oct 21, 2004 | 03:23 AM
  #34
millenniumdna's Avatar
millenniumdna
I think I will add a second one.
Old Oct 22, 2004 | 12:58 AM
  #35
millenniumdna
one quick question. on the 20 OCC the arrow on the cap. should that point to the firewall or to the front end? Im sure i have it right but i wanna be sure lol
Old Oct 22, 2004 | 01:02 AM
  #36
dustyloins's Avatar
dustyloins
Hall of Fame Member
It should be pointing in the direction of the air flow (towards the throttle body, away from the PCV valve).
Old Oct 22, 2004 | 01:04 AM
  #37
millenniumdna
k thanks, thats how it is but for some reason i was doubting myself.
Old Oct 22, 2004 | 01:10 AM
  #38
dustyloins's Avatar
dustyloins
Hall of Fame Member
The posting on srtforums about the OCC pointed that out, and I THINK the instructions with the Cambell-Hausfeld part said to make sure the arrow pointed in the direction of the air flow (since it's actually an air compressor filter).
Old Oct 22, 2004 | 01:11 AM
  #39
millenniumdna
im just trying to find my power lose. So im going over everything i have done with the car. Tommorrow I think im going to leak test it all.
Old Oct 22, 2004 | 01:17 AM
  #40
dustyloins's Avatar
dustyloins
Hall of Fame Member
I've noticed that if my OCC gets more than about 1/2 full, I start getting little oil specks on the tail of my SRT-4. And since I put the Stage 1 on, it fills at least twice as fast as it did before the Stage 1....due to the increase in the boost according to RR.....
