50 trim turbo, Stock PcM?
Old Jun 18, 2007 | 11:06 PM
T_U_R_B_O's Avatar
T_U_R_B_O
Default 50 trim turbo, Stock PcM?
Alright... im serious about getting a 50 trim tubo.. i plan on getting a bigger fuel pump, injectors, turbo back exhaust,all that good stuff.. my only problem is that i have the stock pcm. am i going to have any problems with check engine lights.. if so what do i do.. will i need a stage 3 pcm?? Help plz
Thanks GuyS
Old Jun 19, 2007 | 12:54 AM
flamingpinhead's Avatar
flamingpinhead
Section Moderator
Default RE: 50 trim turbo, Stock PcM?
you could just bypass the PCM altogether as far as fuel management goes.
Old Jun 19, 2007 | 01:47 AM
AznSrt 4's Avatar
AznSrt 4
I don't know much about car performance parts. But, which different from a 50 trim DBB turbo and a stage 3 turbo?
Old Jun 19, 2007 | 02:36 AM
motorboy1's Avatar
motorboy1
ORIGINAL: flamingpinhead
Yea I know a guy around me thats got 50 trim on stage 0, doesn't through any codes cuz the computers pretty much out of the loop with the dtech andw/i, but hes always tunning but hey its a 50 trim you pretty much gotta tune no mater what stage your on
Old Jun 19, 2007 | 04:16 AM
PSI Chick's Avatar
PSI Chick
it's very doable. some people prefer to tune off the s0 ecu, it seems to hold a tune better. you might throw a overboost code, but that would be it.
Old Jun 19, 2007 | 05:47 PM
Aceburner's Avatar
Aceburner
Yeah u should be fine. A lot of people run s1 or s2 (like what I'm going to do since I have it). Depending on your year u might get a code for the exhaust if u go w/o a cat.
Old Jun 19, 2007 | 09:34 PM
T_U_R_B_O's Avatar
T_U_R_B_O
yea... speaking of a cat... if i run my car with out a cat how will i not get any rich or lean codes... since there is an o2 in front and behind the cat
Old Jun 19, 2007 | 09:41 PM
PSI Chick's Avatar
PSI Chick
you get a staged ecu. on the stage ecu's the second o2 sensor reads stoich.
Old Jun 20, 2007 | 08:27 PM
T_U_R_B_O's Avatar
T_U_R_B_O
WiLL a StagE 1 ECU be OK or WiLL i NeeD a StagE 2 ??
Old Jun 20, 2007 | 08:54 PM
Burnnout's Avatar
Burnnout
Stage 1 will do it.
