13 wks.= Stage II
Old Sep 28, 2004 | 10:14 PM
PSI Chick's Avatar
PSI Chick
Default RE: 13 wks.= Stage II
nope, went straight to stage 2
Old Sep 28, 2004 | 10:37 PM
millenniumdna's Avatar
millenniumdna
Well I got a ways to go before I decide which road Im going to be taking. Got the BOV coming Motormount Inserts are next. Followed up with Intake and then exhaust. If im not divorced, dead and kicked out by then I will turn my attention to STAGE upgrades.
Old Sep 28, 2004 | 11:02 PM
glhs837's Avatar
glhs837
I went from having Stage 1 for almost 20K to Stage 2 with toys. WOW!!! Mopar exhaust, as recommended, of course
I've had S2 on for 10K now, still love dropping the hammer, I have thought of naming my throttle pedal Mjolnir, but that will wait for S3
Anyway, lots of function in Dial a Boost alone, and the sprayer is good for 5whp. But the red switch of power is the best thing. And I've only ran it once for three days. Torco is the easiest option, safe and readily available. Another option, not for the weak of heart or the warranty squeamish, but safe when used properly, is water injection. For the price of four cases of Torco, you can have an injection setup that lets you use distilled water to run racegas mode anytime. That's my plan
Since my car will still use ALL of Mopars boost control and safety systems, I'm not worried. If the car detects knock, it'll shut power down, if temps get to high, it'll pull power and richen up.
Old Sep 29, 2004 | 05:23 AM
roachnigga's Avatar
roachnigga
Sweet!!! I havent made up my mind for the Stage 3 yet. I'm really focus on the upgrade turbo when i reach state side....
Old Sep 30, 2004 | 01:49 AM
Danman1's Avatar
Danman1
Hello everyone im new here...Does anyone have an idea what the stage 3 will cost??
Old Sep 30, 2004 | 02:00 AM
glhs837's Avatar
glhs837
Not yet.
Old Sep 30, 2004 | 03:03 AM
roachnigga's Avatar
roachnigga
nope
Old Sep 30, 2004 | 10:54 AM
Danman1's Avatar
Danman1
yea i didnt think so...thanks
Old Sep 30, 2004 | 01:11 PM
Danman1's Avatar
Danman1
Is the mopar BOV relatively easy to put in?? I have mine now but i havent put it in yet. Anyone have any tips on putting it in?
Old Sep 30, 2004 | 06:02 PM
PSI Chick's Avatar
PSI Chick
it's three bolts. it's not difficult to install, but it is a pain.
tips - 1. tie the wrench to your wrist. this saves a lot of time when you drop it 10 times trying to get out the 3rd bolt. 2. put copper rtv on there too, helps prevent leaks. 3. to get the 3rd bolt your best bet is going from the passenger side of the car and putting your arm under the turbo. if you've got short arms this could be a problem.
