Any problems with the srt-4 04's???
Old Oct 15, 2004 | 12:52 AM
dustyloins's Avatar
dustyloins
Hall of Fame Member
Default RE: Any problems with the srt-4 04's???
Unless you take it to the drags and modify it way out of the ordinary, your SRT-4 will be fine in normal, day to day, ricer killing driving.
BTW, the "problem is the #4 spark plug WIRE, not the spark plug......[sm=smiley20.gif]
Old Oct 15, 2004 | 01:05 AM
SRT 4 turbo??'s Avatar
SRT 4 turbo??
Thanks , #4 spark plug WIRE can be replaced , so i should have any worries , thanks for your help[8D]
Old Oct 15, 2004 | 07:35 AM
71RoadRunner's Avatar
71RoadRunner
I have that issue of Modified Mag that you are talking about and if had read the very next sentence (here is the next sentence:"This exact thing happened to Ray Arroyo and his '03 Dodge Neon SRT-4 at Atco Raceway in NJ precisely one week before our photo shoot.") you would know that this happened to the featured car that is pushing out 424 horsepower at the wheels with a stock tranny. Right after this happened the tow truck driver that pulled his SRT-4 off the track hooked up to it wrong and ripped the nose off of it as well.
The only issues with the SRT-4 are the plug wires, which has been mentioned already, and the speedometer developing a slight case of the needle becoming jumpy between 70 and 75 MPH. It is actually only a slight movement back and forth between 70-75 that only moves 1-2 MPH back and forth. These are the only two real issues that I've heard of about the SRT-4's in general. I have also heard of people with '03 SRT-4's having difficulty shifting, but nothing to keep it from being driveable.
Old Oct 15, 2004 | 11:27 AM
Hellboy's Avatar
Hellboy
yes now that you mention it, i do have some trouble putting it in gear. feels like i hit the metal inbetween the gearslots, i just pulll the shifter back a little and the next try it works just fine. i don't race it so it's not much of a problem. a few minor issues with the radio, so what.
Old Oct 15, 2004 | 01:10 PM
PSI Chick's Avatar
PSI Chick
you guys should also know that ray (the car form modified mag) had changed his clutch recently as well to the spec 3i, which has had some issues disengaging, and this was a contributing factor to his tranny giving out. he also had problems with it before even changing the clutch. this was not unexpected that it happened to him given the events leading up to it, nor is it commonplace.
Old Oct 16, 2004 | 03:55 AM
71RoadRunner
Yeah, I forgot to mention the clutch upgrade, they mentioned it in the article.
Old Oct 16, 2004 | 04:25 AM
Gump's Avatar
Gump
if you hold speed between 70-75 the needle will move up and down. the stock cd player will hold a cd in sometimes and its a bitch to get out.
Old Oct 16, 2004 | 05:20 AM
71RoadRunner
Really, I've never had any problems with my CD player. Well, I guess it might be a good thing that I plan on putting my Alpine in it anyway.
Old Oct 16, 2004 | 09:55 AM
Gump's Avatar
Gump
rr do you play burned cd's?
Old Oct 17, 2004 | 03:06 AM
SRT 4 turbo??
They fixed the shifting gears on 04's and 05's right ?
