Any problems with the srt-4 04's???
Old Oct 17, 2004 | 03:07 AM
  #21
SRT 4 turbo??'s Avatar
SRT 4 turbo??
Default RE: Any problems with the srt-4 04's???
Yeah , i just got that mag modified a week ago. Anybody notice the CO2 Cooler intake misters? pretty cool.
Old Oct 17, 2004 | 03:39 AM
  #22
Gump's Avatar
Gump
i dont see a gear problem
Old Oct 17, 2004 | 04:54 AM
  #23
Hellboy's Avatar
Hellboy
you don't see the gear problem, cause it's on my end, not the cars fault.
Old Oct 18, 2004 | 06:08 AM
  #24
71RoadRunner's Avatar
71RoadRunner
I do play burned CD's, but I never tried it in my SRT-4. It doesn't matter now anyway, I installed my Alpine this afternoon. Now I know for a fact that I can play all burned CD's.
Old Oct 18, 2004 | 01:58 PM
  #25
fivetoez's Avatar
fivetoez
Iv'e only had one HUGE prob. after 11,000mi. of driving it......................a $363.00 speeding ticket[:@]
Old Oct 23, 2004 | 07:41 AM
  #26
PITBULL's Avatar
PITBULL
Mine had a problem with holding cd's in the top main unit (not the changer) I found the problem myself though! If you ever run into this problem, the thing that is causing it is that the panel above the cdplayer is put in so tight that it kinda mashes the top of the cdplayer..........The only thing you have to do to correct this is take the main cover off (in a srt it's the whole middle silver thing....by the way, there is 2 screws behind the vents) loosen, the box above it with a phillips screw driver, hold it farther up and re-tighten, then put it back together. this frees up the cdplayer and it will no longer hold the cd's in. Mine works everytime now!
Old Oct 25, 2004 | 07:24 PM
  #27
RIPSIGUY's Avatar
RIPSIGUY
You have to be an IDIOT to blow one of these motors. I do recomend full synthetic oil.......my manifold glows red after a quick run down the country side.
Old Oct 25, 2004 | 09:57 PM
  #28
dustyloins's Avatar
dustyloins
Hall of Fame Member
Yup, it costs more, but it's a small price to pay for so much fun!!!
Just be sure to take your own syn oil to the dealer if you get your oil changes there, or be prepared to pay even more....
Old Oct 26, 2004 | 12:27 AM
  #29
LilSparkPlug's Avatar
LilSparkPlug
Yeah these engines can take quite the beating.
Problems:
1. #4 Spark Plug wire. If your #4 wire looks like the other three, and its white...replace it. If not your CEL will come on and you'll have a misfire.
2. A couple people have had problems with the flywheel bolts backing out on them, destroying the clutch....no TSB on it yet.
3. And yet a few more people have a throttle stick at 3krpms.....
I can't think of anymore right now...if I do I'll letcha know.
Old Jan 16, 2006 | 01:44 PM
  #30
Silverrt4's Avatar
Silverrt4
RR, Is there a specific reason why the needle flutter occurs at 70-75mph. It's kind of annoying when you have OCD tendencies. Is there anyway of fixing this problem. I know this is an old post but I didn't want to start a new one.
Thanks for an replies.
ORIGINAL: 71RoadRunner
The only issues with the SRT-4 are the plug wires, which has been mentioned already, and the speedometer developing a slight case of the needle becoming jumpy between 70 and 75 MPH. It is actually only a slight movement back and forth between 70-75 that only moves 1-2 MPH back and forth.
