passing inspects
Old Aug 20, 2007 | 07:50 PM
zukidragon's Avatar
zukidragon
Default passing inspects
I am running stg2 and could not pass because of auto trans codes so I switched back to 0stg, Now I have 2 not ready codes namley o2 sensor and catalist can anybody help or some advice would be appreciated. Thanks
Old Aug 21, 2007 | 12:23 AM
PSI Chick's Avatar
PSI Chick
Default RE: passing inspects
get the tranny code scrubber from n2mb, problem solved.
Old Aug 21, 2007 | 08:51 AM
iloveboost's Avatar
iloveboost
what is a tranny code scrubber?
Old Aug 21, 2007 | 09:26 AM
PSI Chick's Avatar
PSI Chick
it's a box that gets rid of the tranny codes that s2/s3 throws.
Old Aug 21, 2007 | 01:38 PM
hawwk11's Avatar
hawwk11
ORIGINAL: PSI Chick
Hey there! I am looking into an srt-4 and im glad this was brought up. I live in California and wanted to know would this work to allow me to pass or are there other things to worry about?
Thanks,
Old Aug 21, 2007 | 04:50 PM
PSI Chick's Avatar
PSI Chick
it would pass the obd inspection, but you still have the visual to worry about there. as long as you get a stupid inspector you should be fine lol
Old Aug 21, 2007 | 05:15 PM
hawwk11's Avatar
hawwk11
ORIGINAL: PSI Chick
LOL! So there is a possibility i may fail the visible? What makes this happen, are there things like cats removed?
Thanks, PSI Chick...
Old Aug 21, 2007 | 06:29 PM
roo69er's Avatar
roo69er
what do they look for during the visual inspection... the cat... what else?
Old Aug 21, 2007 | 06:56 PM
hawwk11's Avatar
hawwk11
ORIGINAL: roo69er
They look for cats, gas cap, and there may be a few other things but thats all i know for sure. The rest is mainly the niffer test which is why i aked my previous ? about the stage kits. If there is nothing removed i believe with the code scrubber i will be just fine. When i took my mustang in last year it passed everything except for the visual and thats because Gt mustangs have freakin 4 cats and after my off-road x-pipe it only left me with 2. The guy who didthe smog said everything else passed just fine.
Old Aug 22, 2007 | 12:31 AM
PSI Chick's Avatar
PSI Chick
none of the stage kits remove the cat so you'll be fine with that. s2 swaps injectors, wga and sensors, s3 adds the turbo/manifold as well. that's why i said if you have a stupid inspector. they look so close to stock that most people won't notice the change, but if it's someone that knows about the car they'll be able to spot it. as long as you keep the other stuff stock or put the stock stuff back in (like intake, tb, etc.) if you change it you shouldn't have a problem.
