WOT SHifts.......
When i first got my car, i'd of NEVER even thought of trying to WOT shift this thing, it just seemed too fragile to attempt such lunacy....................BUT then came the stage 1, & in the instruction's , it tell's you how to WOT shift to improve times(?),.soo i tryed-it, & once i got the hang of it...DAMM, .it's almost as good as SEX!..........the trick in it , stem's from being able to go from gear to gear w/out shocking the drivetrain excessivly..........& they way i do it is , to make sure the the tires are spinnin good BEFORE, bangin 2nd.,........that way they just keep spinnin through 2nd.............RUBBER ,SMILE's & dropped jaws EVERYWHERE!!!__________5TOEZ_________
Ok you all are talking about speed shifting (what I call it) you never let off the gas just slam the gears by nudging the clutch in enought to shift??
if so that is how I shift when I race! Normal dring shift reguraly but when racing or getting on it that is what I do all the time.
The trick is to sit in the drive way figure out how far the you need to push the clutch in to shift, after you get that start to practice.
Its natural to me! No one ever showed me I tryed to show my friends how but they could never get it right grind the crap out of a gear or miss.
I dont know how to explain it other then that you have to lear to figure your car out and lear to listen. I never even look at the gagues I listen to the engine. My friend Kevin he kept asking me what I shift at in the car and what PSi I am running at diffrent RPS "I told him youknow me I dont look I listen" shook his head
Ya'll say WOT and I say WFO (wide F uckin' open hence my screen name on yahoo... What ever it may be, it's allllllllllllllllllllllll FUN FUN FUN...
[IMG]local://upfiles/8970/9A615089CFEF413597643BF6EE7CDA4E.jpg[/IMG]
its easy when you take off never never let of the gas! just push the clutchin shift and while ****ing quickly let of the clutch all should happen in about 1 second or less perfer less!!
