Stage 3
Old Oct 10, 2007 | 03:44 AM
BLKSRT4's Avatar
BLKSRT4
Default Stage 3
If i decide to buy a stage 3 is there anything else i should buy with it to help it run better. or anything to keep the efficency up on the car?
Old Oct 10, 2007 | 08:14 AM
Burnnout's Avatar
Burnnout
Default RE: Stage 3
There is nothing that you "need" per say...... but I would invest in a clutch and a bigger front mount.
Old Oct 10, 2007 | 09:39 AM
MEandmySRT's Avatar
MEandmySRT
Default RE: Stage 3
what BLKSRT4 said andalso a3" s3 o2 housing and turbo-back exhaust upgrade.
Old Oct 10, 2007 | 06:30 PM
Nicky B's Avatar
Nicky B
Default RE: Stage 3
Obviously better tires
Old Oct 11, 2007 | 12:19 AM
PSI Chick's Avatar
PSI Chick
Default RE: Stage 3
there are lots of things to make s3 run "better" but it's all about how much money you want to spend and what you want to do with the car
Old Oct 11, 2007 | 05:03 AM
BLKSRT4's Avatar
BLKSRT4
Default RE: Stage 3
i just want the car to be able to run without having to do internals "YET." i already have an o2 housing, and a mpx single exhuast. intake, OCC, turbo timer, an external BOV, And brand new tires like 1 month ago
Old Oct 11, 2007 | 08:43 AM
Burnnout's Avatar
Burnnout
Default RE: Stage 3
You can do alotwith S3 before having to do your internals.....just look at psichick.
Old Oct 11, 2007 | 10:51 AM
PSI Chick's Avatar
PSI Chick
Default RE: Stage 3
you can get lots of power out of s3 without internals, but there is a point that you do need to build the motor. once you're in the 450+hp range the motor should really be considered, before that you're fine.
other good mods that s3 loves are a fmic, w/i, and a tb. there's always a wga/mbc combo if you don't mind losing your toys (apparently there is a way to keep functionality but i haven't looked into that).
Old Oct 11, 2007 | 03:01 PM
lblackneon's Avatar
lblackneon
Default RE: Stage 3
What is a w/i?
Old Oct 11, 2007 | 03:03 PM
PSI Chick's Avatar
PSI Chick
Default RE: Stage 3
water injection
