tranny fluid change
Old Oct 19, 2007 | 09:43 PM
baytech24's Avatar
baytech24
Default tranny fluid change
this is going to be my 1st tranny fluid change how much do i need my car has 60,000 miles
i bot a gallon of ATF 4 and a bottle of royay purple synchromax
but i dont know if thats right can use the oe stuff and use the rp synchromax *** a friction modifier???
///silver with conversion kit bov greddy boost contoller and turbotimer (profec2)
Old Oct 19, 2007 | 10:25 PM
dustyloins's Avatar
dustyloins
Hall of Fame Member
Default RE: tranny fluid change
Put 4 ounces of the friction modifier in first, then top it off with about 2.5 quartsof the ATF-4.....
Dusty
Old Oct 19, 2007 | 11:15 PM
baytech24's Avatar
baytech24
cool thanx can the synchromax beuse like friction modifier
Old Oct 20, 2007 | 04:23 PM
dustyloins's Avatar
dustyloins
Hall of Fame Member
http://www.srtforums.com/forums/arch.../t-332069.html
As you will see from the above link, a lot of people use different friction modifiers......
Dusty
Old Dec 16, 2007 | 10:08 PM
srtratblock's Avatar
srtratblock
Friction modifier, and top off with synchromax. this is full synthetic. Change mine at 18,000. Then Ichanged at 50,000, still looked brand new.
Old Dec 17, 2007 | 12:29 AM
flamingpinhead's Avatar
flamingpinhead
Section Moderator
i change out the tranny fluid every 15k. looked good both times. first change i used the mopar additive, second time i used another brand
Old Dec 17, 2007 | 12:38 AM
PSI Chick's Avatar
PSI Chick
to answer the question, no synchromesh is not the same thing as friction modifier. if you were going to use all synchromesh then you wouldn't necessarily need extra fm, but if you're going to use mopar atf then you need a seperate fm. you can get it at any dealer.
Old Dec 17, 2007 | 10:11 AM
srt4ever's Avatar
srt4ever
I got mine(modifier) from the dealer...his price ...$4.95 for the bottle.
Old Dec 17, 2007 | 07:25 PM
Moparmatt440's Avatar
Moparmatt440
Personally when I do mine Im going straight royal purple, I wrote them and they said that many people have added the fm with their syncromax and runs fine or have run straight syncromax and never had a problem. I love the way it perfored in the SXT trans, course no posi in it
