My car??
Old Nov 6, 2007 | 09:36 AM
Kapitald's Avatar
Kapitald
Default My car??
When I hit wot my boost needle bounces around alot.........does this indicate i have a boost leak???
Occasionaly it holds....but most the time its fluttering around way too much and too hard to read... any help would be appreciated..
Old Nov 6, 2007 | 09:41 AM
Burnnout's Avatar
Burnnout
Default RE: My car??
Sounds like you got a broken gauge really..... could be a boost leak....... does the car act abnormal or sounds abnormal when this is happening ?
Old Nov 6, 2007 | 10:02 AM
faststage02005's Avatar
faststage02005
do you still have the mopar bov????
if you do that could be why....
Old Nov 6, 2007 | 01:47 PM
srt4ACRboy's Avatar
srt4ACRboy
ORIGINAL: faststage02005
he has an HKS BOV read mods list, its most likely the ****ty boost gauge that comes with the car
Old Nov 7, 2007 | 04:02 PM
Kapitald's Avatar
Kapitald
Thanks for the replies.....the boost gauge is the one you can buy at autozone and goes to 30 psi.....i think the brand is autometer....seems like if i ease into wot slowly (instead of stomping on the gas) the needle is okay....but if i downshift into second and stomp on it it flutters alot.....only does it at high boost....if i turn the boost down it doesnt flutter so i think the gauge is okay....
i was just wondering if i had a boost leak...i hope not....
Im in the process of building one of those pressure testers for our cars...
Old Nov 7, 2007 | 04:05 PM
Burnnout's Avatar
Burnnout
In your other post it shows your boosting 26 psi on the stock turbo ...... this is your problem!
Old Nov 8, 2007 | 09:33 AM
Kapitald's Avatar
Kapitald
no i dont boost at 26.....i mightve done it one time after we hooked up the boost controller.....the stage 2 was boostn at that when i beat him.....my needle flutterswith my boost set to19 and 20 psi
Old Nov 16, 2007 | 12:48 AM
m88s22's Avatar
m88s22
could be yourmotor mount inserts.my guage startedto dothe same thing after i put in my solid mounts.
