changing my oil what to run?
Old Mar 31, 2008 | 04:09 PM
Kapitald's Avatar
Kapitald
Default changing my oil what to run?
I seen a thread looks like everybody in their brother uses mobile 1 with the exception of a few running amsoil...
i usually run castrol full synthetic 0w-30 or 5w-30
what do you guys think i should run now...its kinda in the back of my mind that yall are gonna say mobile 1 lol
Old Mar 31, 2008 | 04:32 PM
srt4ever's Avatar
srt4ever
Default RE: changing my oil what to run?
Mobile 1 for me, I see all this other stuff, but I like that Mobile 1 is the choice for Corvette, and other Hi-Po cars out there.
I use 5W-30, at least thats what the cap says to use, I have heard of others going 10W-30 but, IDK about that...
I have heard that some 2.4's take 10W-30 but that may just be a rumor???
Old Mar 31, 2008 | 04:48 PM
Kapitald's Avatar
Kapitald
yeah i heard that too....but i also heard lilsparkplug and redneonrt like to run 0w 20 - 40
Old Mar 31, 2008 | 04:52 PM
LilSparkPlug's Avatar
LilSparkPlug
I run 0w40 in the winter.[/align]5w30 the rest of the year.[/align][/align]All Mobil 1 Full Syn[/align][/align]The 03s manual stated that they should run 10w30, until an addendum came out with the 04s that said running 5w30 was better. [/align]
Old Mar 31, 2008 | 08:04 PM
dustyloins's Avatar
dustyloins
Hall of Fame Member
LilSparkPlug is right. The only reason I didn't switch over when the notice came out is that it was related to EPA gas mileage (thinner oil = more miles). I live in the DEEP south and she is in the frozen north.... However, Mobil 1 is your best bet at $23 for 5 quarts at Wally World vs. 20% more for Amsoil despite what they say about extended oil changes. (Read the fine print, the extended oil changes DON'T apply to turbo cars like the SRT-4)
Dusty
Old Mar 31, 2008 | 08:27 PM
LilSparkPlug
Yeah stay at 3k intervals. My friend decided (against my advice) to run his car right past the 5k mark.....he had about 2 quarts of oil in the car, maybe 2.5. Just because the oil says you can do it....doesn't mean you can.[/align][/align]If they told you to jump off a bridge...would you? Save the $3-5 and buy the regular Mobil1 Full Syn, not the extended.[/align]
Old Apr 1, 2008 | 07:35 AM
AWH's Avatar
AWH
I have an 03 and the manual says to use Mobil 1 synthetic 10W-30 but then I received the amendum stating 5W-30 is reccommended. I had the dealer do my first couple oil changes until I realized they were using Quaker State Synthetic Blend 15W-40. Idiots.
Now I do my own oil changes every 3,000 miles using either Mobil 1 or Lucas Synthetic 5W-30. Lately I've been using the Lucas. It's only a few cents more than the Mobil 1 and it contains the Lucas oil stabilizer. Seems pretty good. And I don't see why Castrol Syntec would be bad. I used to put castrol in my old 95 neon all the time.
Old Apr 1, 2008 | 02:36 PM
dustyloins's Avatar
dustyloins
Hall of Fame Member
Your 95 Neon could run forever on Castrol Syntec with no problems. However the 2.4 turbo engine in the SRT-4 puts a much bigger demand on the oil, especially in how it stands up to the heat a turbo engine produces. Dino oils or dino blends break down much faster than full synthetics under high temp operating conditions. There's a reason Dodge recommended full synthetic, and it wasn't because they own part of Mobil.....
Dusty
Old Apr 1, 2008 | 04:32 PM
srt4ever's Avatar
srt4ever
[sm=badbadbad.gif]It gets mighty hot in our 2.4L engines!!!!!
Just got mine changed at 3350 miles and it looked kinda bad and smelled burnt[:@]
It just kinda surprised, but I guess with all the winter warm-ups and winter driving
it was to be expected, also put on the Purolator Filter (with Fiberglass filter element)
and check valve(built in)so I dont starve the oil pump at start-up...just to be safe
Old Apr 1, 2008 | 06:18 PM
LilSparkPlug
Oh yes it does. I put a 180 T-stat in to take the temperature down a notch, I wasn't feeling the needle above 200 as often as it was. Normal operating temperature can be up to 230ish! Yeah....no. I usually run the Mopar filter, but this time I bought the Mobil 1. It was like $2 extra, surprisingly I didn't get raped on it.
