exhaust/engine light
Old Apr 26, 2008 | 04:04 PM
zukidragon's Avatar
zukidragon
Default exhaust/engine light
I was wondering if doing a cat-back exhaust would make the check engine light come on, or if it would prematurely burn out either of the O2 sensors ?
Old Apr 26, 2008 | 06:10 PM
LilSparkPlug's Avatar
LilSparkPlug
Default RE: exhaust/engine light
No it shouldn't. But if you replaced the cat with a straight downpipe that would cause a P0420 Catalyitic Converter Inefficiency code.
Old Apr 26, 2008 | 08:25 PM
taekwon11's Avatar
taekwon11
My car is Stage 2 and I am getting ready to do away with my cat. Will I get the code you mention? Someone else said previously that the S2 ECU doesn't check. Thanks for your help.
Old Apr 28, 2008 | 07:18 PM
zukidragon's Avatar
zukidragon
Is there any way to fix it, or do I have to re-install my cat for inspect?
Old Apr 28, 2008 | 07:28 PM
PSI Chick's Avatar
PSI Chick
it doesn't matter, it will read stoich
Old Apr 28, 2008 | 07:42 PM
Plan B's Avatar
Plan B
You will pass emmissions with or without a cat and be code freewith a staged PCM
Old Apr 30, 2008 | 07:06 AM
prpaster's Avatar
prpaster
I thought you will fail emissions with a staged PCM becuase it throws a skim Key Code
Old Apr 30, 2008 | 11:38 AM
PSI Chick's Avatar
PSI Chick
key code has no effect on emissions testing
Old Apr 30, 2008 | 11:44 AM
prpaster's Avatar
prpaster
Yea but i thought some states would not pass you if you have engine codes showing. Just something to look into. Thank God Michigan doesnt have emission testing
Old Apr 30, 2008 | 01:01 PM
Plan B's Avatar
Plan B
Even if your state is that strict, you can go to the dealership and have the SKIM re-programmed, which is a good idea anyways for security purposes
