Stage 2 Problem
Old Sep 7, 2008 | 01:09 AM
mpain10's Avatar
mpain10
Default Stage 2 Problem
i jus got the stage 2 mopar kit and got it on and all but im only peekin at 15....i thought it was spose to be like 19...any suggestions on what could be the problem....
Old Sep 7, 2008 | 10:53 AM
PSI Chick's Avatar
PSI Chick
your wga probably isn't adjusted properly
Old Sep 7, 2008 | 04:33 PM
mpain10's Avatar
mpain10
im outside facing the engine does the wastegate go all the way to the left or right.....
Old Sep 9, 2008 | 01:43 PM
PSI Chick's Avatar
PSI Chick
it doesn't go all the way either way. you want the wga to have a 4mm preload on it. take off the wga. mark where the body and the arm meet with a sharpie. install the wga and make sure that there's 4mm from the line that you drew to the body of the wga. if you tape 4 dimes together it's roughly 4mm, just use that as measurement.
Old Sep 9, 2008 | 02:21 PM
mpain10's Avatar
mpain10
im kinda lost can u be more detailed im sorry new to this
Old Sep 9, 2008 | 05:11 PM
PSI Chick's Avatar
PSI Chick
i honestly don't know how to be more detailed than that. what are you not getting?
Old Sep 9, 2008 | 11:17 PM
LilSparkPlug's Avatar
LilSparkPlug
Dude seriously...did you not get my PM? How many times are you going to post the same thread? You posted this same thread THREE times. Stop posting threads about the exact same subject. Its annoying. I answered you in the other thread, and Amy answered you here. Don't post another new thread about it again.
Old Sep 14, 2008 | 06:16 PM
Pressurecooker's Avatar
Pressurecooker
stage 2 does not peak at 19.
It peaks at 16, but if the air is cold, maybe 15 or so.
besides wga adjustments, you may have a boost leak. check clamps etc.
