Spark Plugs
#21
RE: Spark Plugs
bellosiciliano18
the iridium deals with the material used in the electrode of the spark plug. they have used materials from copper, to platinum, to iridium, to nickel... platinum was the big thing not too long ago, but as we all learned by watching rap video's - platinum is expensive... for our cars the PLZTR5A-13 is the best NGK plug you can get for the car (good luck finding them though)... most aftermarket companies offer LZTR5AIX-13's (which are the iridiums)... now, I am biased, I work for NGK... so of course I am going to tell you/anyone to get them...
just out of curiosity Amy, why do you prefer the Denso's? Gotta "know thy enemy"
#22
RE: Spark Plugs
i have seen the benefits of using them over the ngk's. a lot of the big turbo people use them and it really does seem to help control blow out and smooth out the idle. i've been using the ngk 4306's since they were released, and although i am pleased with how the car has responded to the plugs (smoother idle and less break up at higher rpms) i have not been pleased with the way that the plugs wear. i'm already on my 5th set of plugs. i have had to change them every 2-3 months, and at each change i can feel the car perform better, but then it quickly goes back to break up. i know that plugs aren't that expensive, but it's a little much to be going through 5-6 sets a year at $10 a piece. for the same money i can get a set of denso's that i know won't cause me the same issues.
the only reason that i haven't changed over to them yet is because i was waiting until s3 arrives. denso's should not be gapped, so i wanted to wait until i had the larger turbo so i could use the 22's and not have to buy multiple sets (at $12 a plug i don't want to do it twice). so now that s3 will be here soon, i'm buying the denso's.
i have seen multiple big turbo cars try both the ngk's and the denso's, and it just seems that the cars respond better to the denso's. now i haven't seen many of these cars use the irridiums long term, as most owners around here are using denso's once they increase boost or go with a bigger turbo. do you have any data as to how the irridiums compare to the desno's?
#23
RE: Spark Plugs
It looks like I'm late to the party, but I'm pretty sure the stock Champion spark plugs are the same ones used in the 2.0L engines.
Talk about cutting corners.
I've heard/read about more failures with the aftermarket coils than with the OEM units. RR had one so why not use it, but I wouldn't spend the money on it though for the SRT-4.
The heat shield is a great idea to help keep your wires from roasting.
As you upgrade, you're going to need to upgrade your plugs and close your gap accordingly.
#24
RE: Spark Plugs
#26
RE: Spark Plugs
Hello? Newcommer to this sight and need some help. I have a red 04 srt-4 neon 18K miles and had a spark plug blow out. It is an all stock car no mods done and dodge machanic giving me crap about fixing it. We have the extended warranty and of course it is always a catch 22 when you need something fixed. First thing he said was the other three spark plugs were loose...and when I argued then he said theblown out spark plug had tool marks on it and looks like it may have been tampered with.I wanted to know if the loose plugswould have contributed? the other argument is bull cause no one messed with the car besides when I get the oil changed. I don't race much unless I'm late to work.The spark plug was fine but the threads in the head were stripped. It means $250 bucks to have them thread lock it or 2K to get the thing sent in and repaired the right way. Any input would be great. I'm at my wits end[&o]
Suzanne
Suzanne
#27
RE: Spark Plugs
ORIGINAL: westsuzanne
Suzanne
Suzanne
Stripped threads?? improper torque probably - too tight! of course, if the plugs are loose, I wonder if the heat developed would affect the threads... just an idea, no proof on that one...
loose plugs will lead to an increase of cylinder temps, which in turn leads to potential pre-ignition... aka, no more motor!
#28
#29
RE: Spark Plugs
ORIGINAL: srt4ACRboy
hotter NGK Iridiums IX
The Stock Heat Range is a 5... NGK rating - the higher the number = colder (safer) plug...
