Spark Plugs
RE: Spark Plugs
I realize I work for a Spark Plug company... but I would strongly suggest replacing the Champions. There is a quality issue (the Champion not having a high quality) here. I, of course, would reccomend the NGK's, but any plug with a heat range similar to the LZTR5AIX-13 would work.
RoadRunner... spark blow out? could you elaborate?
Trending Topics
RE: Spark Plugs
ORIGINAL: SRT_YA
I guess I must be the only one that has had great luck with Champions.
RE: Spark Plugs
My set boost is 25%
My gain is set at 23%
Set gain at 145 or in Kpa 1.00 (15 lbs)
Car is running at 15 psi consistently on low boost setting. Have not adjusted high boost setting yet. Just installed NGKs today. The car isn't backfiring anymore. Stock plugs were seriously carbon failed. Ordered MSD coil anyway because I have the wires. Should be in soon. I think I'm going to turn the low boost setting up to 16 psi.
