neon srt-4 cheap performance mods
Old May 30, 2009 | 07:57 PM
booster86's Avatar
booster86
Default neon srt-4 cheap performance mods
i just recently purchased a 2004 srt-4 i was wondering what mods i should put under the hood. i am on a rather tight budget though
Old May 31, 2009 | 02:44 AM
lblackneon's Avatar
lblackneon
If you're on a tight budget, an intake and exhaust would be a good start. There's so much u can do to these cars. It obviously depends how much u want to spend.
Old May 31, 2009 | 09:57 AM
sarguy01's Avatar
sarguy01
Intake is not worth it unless you have a lot of other mods. It has been proven the stock intake can support over 300 HP. An exhaust would be my first, a wideband second, and a boost controller third. Do not turn up the boost until you have a wideband.
Old May 31, 2009 | 08:33 PM
booster86's Avatar
booster86
what exactly is a wideband and what does it do?
Old May 31, 2009 | 09:07 PM
sarguy01's Avatar
sarguy01
A wideband is a gauge that uses a 5-wire O2 sensor to keep you informed of the air/fuel ratio. It goes into the exhaust. You don't want to up the boost without one.
Old May 31, 2009 | 09:29 PM
newbiesrt4's Avatar
newbiesrt4
y not?
Old Jun 1, 2009 | 02:06 PM
sarguy01's Avatar
sarguy01
Originally Posted by newbiesrt4
y not?
Seriously? If you push too much boost and the air/fuel ratio becomes lean, you can melt a hole in a piston, melt spark plugs, etc.
Old Jun 2, 2009 | 02:21 PM
70x7's Avatar
70x7
The car runs really rich from factory, so you COULD raise the boost a little, but I wouldnt go more than a couple psi without the above^.
Not just the catback though, that itself wont really help alot. Most of the power will be freed up from the addition of a 3" downpipe and o2 housing.
Back when I got mine, the Stage computers were really good mods to do, but now there are many options without them..diablo and the like.
