showing a P 0340 code need advice
Old Sep 30, 2009 | 04:38 PM
zukidragon's Avatar
zukidragon
Default showing a P 0340 code need advice
This morning I drove to work and things were fine but after 10miles or so if I pressed the gas and went above 2500rpm it would stutter and bog down, it idles fine and once it cools down it revs fine. The code is a crankshaft positions sensor please advise.
Old Oct 13, 2009 | 01:11 PM
srt4rez's Avatar
srt4rez
Erase the code and see if it lights up again. If it does then most likely it is the sensor being detected.
Old Oct 13, 2009 | 02:19 PM
70x7's Avatar
70x7
My guess would be you need to replace your crankshaft sensor.
Old Nov 16, 2009 | 10:06 PM
zukidragon's Avatar
zukidragon
Default Thanks
Reset the computer and that seemed to fix it. Computer snafu
Old Nov 18, 2009 | 03:03 PM
amoeba's Avatar
amoeba
If you rec'd a code, it may be an early warning sign of a future failure of the Cam Position Sensor, or as you mention just a glitch, which could be the ECU, or the sensor having a bad day.
If it happens again, replace the sensor.
JS
Old Feb 5, 2010 | 02:04 AM
streetbikr600's Avatar
streetbikr600
same here the same exact thing happens to me i changed it like a month ago and it just came on again. now its like once a week. goes away and comes back...ugh...i got 98k miles almost stock i think s2 injectors timing belt and tensioner and plugs should to the trick. cuz when the check engine light comes off it pops through the intake and exhasut under a load
Old Feb 22, 2010 | 04:07 PM
Stainz05's Avatar
Stainz05
A camshaft sensor ($35) from Advance Auto fixed mine. 56K - changed plugs (OEM Champion RE14MCC5 @ .085"! Changed to Champion #3570 Pt.). Aftermarket gascap tossed - MOPAR $15 cap got rid of the sporadic gas cap codes. Occasional irrelevant EGR code thought to be leaking resevoir on OCC. Runs like new - she ate up the rest of her Kumho tires - see other thread.
Stainz
Old Feb 25, 2010 | 01:45 AM
amoeba's Avatar
amoeba
Stainz
Champs gapped at .085" .045" is stock, but if you're pushing more boost, reduce to .035" to avoid blowout of spark. Sure wider can be better, but when I ran stock STG 1, .045" was fine, but going to STG II needed smaller gap, as I encountered blowout at .045" All is well now, no problems!
Old Feb 28, 2010 | 08:49 AM
Stainz05's Avatar
Stainz05
The OEM Champs had .085" the first time they were off the car - 56k! The center electrode was quite short. I just can't believe they didn't spring for Pt's! Of course, it came with dino-oil in it, too. Still runs like a top. I still need a new code reader - it won't come from H-F, that's for sure. I'm guessing the plugs needed changing at 24k.
Stainz
Old Mar 2, 2010 | 12:28 AM
amoeba's Avatar
amoeba
Stainz
Code reader? On an SRT4 you don't require a reader as you can get the codes via the igniton/key switch. You are aware of that I am hoping, so why waste $$$ on a reader? If you need a list of the code definitions shoot me a PM and I'll provide you with the list.
