Thinking about the Stage 1
Old May 3, 2005 | 06:16 PM
Silverrt4's Avatar
Silverrt4
Default Thinking about the Stage 1
Could anyone tell me the positives of the Stage 1 Upgrade. I think I am def. going to buy it next month, I have all the other upgrades such as the Intake, exhaust, wire & plugs. What kind of horse power will I be pushing after I get the upgrade. If anyone ordered the stage1 from Modern Performance how long did it take for you to get it. Thanks for any replies.
Old May 3, 2005 | 08:49 PM
200srt4's Avatar
200srt4
Default RE: Thinking about the Stage 1
check either mopar.com or modernperformance.com...noth of these sites post th numbers you'll be putting out and explain what you're getting
Old May 4, 2005 | 08:26 AM
71RoadRunner's Avatar
71RoadRunner
Stage 1 is very nice and it's best feature is the quicker boost, where you would be on the gas for around 3 psi boost will now be around 7 psi boost instead, it really livens it up. I got mine from Modern and it took 3-4 weeks from when I ordered it. It's a pain getting the PCM and bracket in and out together, it will be easier if you check the hose clamp on the intercooler where the PCM bracket goes around it. If the part that contains the adjustment bolt for the clamp is in your way, most likely it will be, loosen it and rotate that part to the bottom out of your way, this will make it much easier. Just do not forget to reposition the clamp and retighten it when you have the Stage 1 PCM and bracket back in place and bolted down.
Old May 4, 2005 | 11:24 AM
Silverrt4's Avatar
Silverrt4
Thanks RR
Old May 4, 2005 | 12:38 PM
fivetoez's Avatar
fivetoez
I REALLY enjoy the extra snap's,pops & burbles ,comin out the pipes on de-cel., & the WOT boost hold is a nice feature also!___________5TOEZ_________& then there's the stage 1 emblem!........WOOT!
Old May 5, 2005 | 08:56 AM
71RoadRunner
Not a problem. Enjoy getting a Stage 1, I know I have.
Old May 5, 2005 | 11:56 AM
RIPSIGUY's Avatar
RIPSIGUY
I ordered mine thru Mopar, and it took two and a half weeks. Go Modern. There is no warranty on these parts anyway, so go with who gives the best service. Modern has given me great service....so far.
Old May 5, 2005 | 01:58 PM
roachnigga's Avatar
roachnigga
You cant go wrong with stage 1, Bro. and your perfomance would be greater with the addtional mods you already have.[sm=gears.gif]
ORIGINAL: Silverrt4
Old May 5, 2005 | 03:25 PM
RIPSIGUY's Avatar
RIPSIGUY
The other nice thing with Stage 1 is it is desensitized to certain codes.....like overboost if you use a boost controller. I think for the money, it is a great place to start.
