where is the blow off valve
Old May 23, 2005 | 11:56 PM
srt4xnj's Avatar
srt4xnj
Default where is the blow off valve
i just got my car in oct and want to replace the stock blow off valve and change it with the mopar one. where is it? so i can change it
[IMG]local://upfiles/11244/B49BE816E79A4537BD718537F13DF7A9.jpg[/IMG]
Old May 24, 2005 | 12:23 AM
LilSparkPlug's Avatar
LilSparkPlug
Default RE: where is the blow off valve
The stock "blow off valve" Isnt even a blow off valve, since it doesnt vent air to atmosphere. Its a "surge valve". The Mopar BOV Conversion plate goes between the stock turbo housing and the stock surge valve plate.
Check this out for complete installation instructions:
http://www.dodge-srt4.com/howto/bov.html
The Surge Valve is directly to left and below the air intake tube (be it stock or aftermarket), and slightly below and to the right of the stock wastegate. Check the picture I attached, thats the plate installed on my car.
[IMG]local://upfiles/8899/2DB03490F3C84495B89FD19CCFD77135.jpg[/IMG]
Old May 24, 2005 | 05:18 AM
roachnigga's Avatar
roachnigga
Many pple here will tell you that it'll create leaks over time. That rather save ya pennies and get a real BOV.
I have a mopar Bov adn im been having a litle boost issues. And yes, i checked for leaks + i had leak solution.
So i oredered a BOV
Old May 24, 2005 | 11:11 PM
srt4xnj's Avatar
srt4xnj
thanx for ur help. those steps that u sent me,put my mind to ease cuz they wanted 142 dollars to put it in was not tryin to pay that.
Old May 25, 2005 | 12:40 AM
LilSparkPlug
I made my own gasket, much thicker than the one that comes with the Mopar BOV, and I also sealed it with Permatex Hylomar HPF (on both sides accidentally, but it all worked out). Theres absolutely NO leaks whatsover, and with the HPF and thicker gasket I get an entirely different sound than the other people around here with Mopar BOVS, its a bit deeper, not pitched quite as high. I like it.....to each his own.
Old May 25, 2005 | 01:09 AM
whoosh's Avatar
whoosh
How'd you make your own gasket?
Old May 25, 2005 | 01:53 AM
LilSparkPlug
You buy the roll of gasket material that they sell at any autoparts store, and cut it to fit the area with an exacto knife. Theres three seperate thicknesses. I got the higher one so that I'd avoid a leak. And then sealed it immensely with the hylomar. And Im STILL boosting strong....5 months later.
Old May 25, 2005 | 02:00 AM
whoosh's Avatar
whoosh
lol, i think the immense amount of hylomar mightve done it..[8D]
Old May 25, 2005 | 02:01 AM
LilSparkPlug
I think it did, cause you couldnt get that BOV off if someone paid you!
Old May 27, 2005 | 03:36 PM
roachnigga's Avatar
roachnigga
i TOOK PSI, ROUTE. I WENT AND ORDERED THE E.D. KIT WITH AN GREDDY BOV.
I JUST ORDERED, FROM LOGIC PERFORMANCE, AGP MOTOR MOUNTS, 180 DEGREE STAT, BOP, AND A PERRIN RADIATOR KIT (RED).
ALSO, RED-LINE XMNS FLUID. IM AT A LITTLE OVER 16K'S.
JUST WANTED TO VOICE THIS
PEACE
