Mopar Performance Stages 1, 2 & 3
Old May 16, 2008 | 10:57 PM
  #41
streetbikr600's Avatar
streetbikr600
Default RE: Mopar Performance Stages 1, 2 & 3
could i just by the injectors and computer..cuz i have the tib and map senor already arg waste gate
Old May 18, 2008 | 12:19 AM
  #42
zzeiler's Avatar
zzeiler
Why so much mopar? I perfer AGP, more power less money. Doesn't keep your factory warrenty, but how many of you have under 30k miles?
Old Jul 15, 2008 | 12:45 AM
  #43
SRT4Fanatick's Avatar
SRT4Fanatick
I am interested in the stage 1 kit for the new computer... I was thinking that you could send in your stock one somewhere to get it tuned but i wanna know more about this one. Will it re-map your fuel better and all the good stuff? And how much more power do you guys with the stage 1 feel?
Old Sep 2, 2008 | 10:58 AM
  #44
blkkn8_65's Avatar
blkkn8_65
New Member
i had bolt on mods donr to a 05 srt-4 and keep getting eng light codes for evap and overboost had a agp billet adjuater put on turbo timer and afc by apexi along with a wideband afc by aem.i was told i need a stage1 pcm or 2 tofix any more eng codes can you verify this before i spend another four or five hundred if its not going to work.
Old Sep 2, 2008 | 11:01 AM
  #45
blkkn8_65's Avatar
blkkn8_65
New Member
will a stage 1 pcm stop eng light codes from mods done on a srt
Old Jan 7, 2009 | 09:04 AM
  #46
Unique Designs's Avatar
Unique Designs
no it wont...i run a big wheel stage 3 with toys and love it
Old Jan 14, 2009 | 07:08 PM
  #47
03blacksrt4's Avatar
03blacksrt4
What is the difference in size of a 03 srt4 injectors and a mopar stage 1(number of CC's please) if i put the mopar stage 1 injectors on my 03 srt4 do i have to change anything else like the computer? and with the satge 1 injectors will i be able to run more boost if yes how much more? help please
Old Jan 14, 2009 | 09:16 PM
  #48
03blacksrt4
Default srt4 questions
what is the difference in size of a 03 srt4 injectors and the mopar stage one injectors(does the 2004 and 2005 models come with the stage one injectors). If i put the stage 1 injectors in my 03 srt4 do i have to change something else like the ecu? will i be able to boost more with the stage 1 injectors if yes how much more.
thank you
Old Jan 14, 2009 | 10:25 PM
  #49
Unique Designs
thank you
the 03 injectors are purple in color and flow 383cc.... the 04-05 srt4 injectors are black in color and flow 577cc.. the stage one injectors are the same as 04-05... the stage 2 and 3 are the same and flow 683cc.....
you can put stage one injectors in an 03 without changing anything else..its not that you will be able to boost more just ur car wont be starving for fuel and get fuel cut
Old Jan 14, 2009 | 10:28 PM
  #50
Unique Designs
if you keep throwing codes for your evap system that means you need to change your gas cap lol.... serious.....no you dont NEED a stage one or 2 or 3 to get rid of overboosting but i do hear alot of people use the stage 1 and it gets rid of the code
