Overheating
Old Mar 31, 2004 | 02:00 PM
roachnigga's Avatar
roachnigga
Default RE: Overheating
837,
Thanks cuz, i did the code and "done" was displayed. does that mean it ran a diagnostic on the car?
Ill check out the site.
Peace
Old Mar 31, 2004 | 03:54 PM
glhs837's Avatar
glhs837
Yep, done = no codes stored. It's possible to have codes that do not trigger the CEL (check engine light).
You have about exhausted what you can or should do with a car still under warranty. Exactly what were the symptoms? Gauge on red, venting steam? Both?
Old Mar 31, 2004 | 04:36 PM
roachnigga's Avatar
roachnigga
Da gauge was red. this just happeed after a race down the Autoban.
The vehicle warranty is shotcause of the Mods installed..but, its cool i have a mech.
Old Mar 31, 2004 | 04:37 PM
roachnigga's Avatar
roachnigga
Thanks Bro!
Old Mar 31, 2004 | 05:23 PM
glhs837's Avatar
glhs837
Which mods do you think void your warranty? You know the mod has to cause the problem for the repair to not be warrantied, right? Look on sema.org, search for warranty. Tons of good info. If your mod list in your sig is accurate, I can't see anything that would cause the overheat. Have you hooked up with of the other SRT-4 owners in Germany? Must be at least 5 or 6 of them. Where in Germany are you at?
Old Mar 31, 2004 | 05:42 PM
roachnigga's Avatar
roachnigga
837,
Naw, Dawg. I havent hooked up with any Srt4 owners. as for where im at, im at Gieb. itz about 15 min from Wurzburg.
And I love... Smoking those A4's, dude....
Old Mar 31, 2004 | 07:04 PM
dustyloins's Avatar
dustyloins
Hall of Fame Member
Man, I miss driving on the Auutobahn!!! And the beer!!! But not the rain/fog/ice.
BTW, when I said "turbo", it was a reference to the type of car, not a specific part. And I DIDN'T know that the turbo was cooled like that either...interesting.[sm=smiley4.gif]
Old Mar 31, 2004 | 07:34 PM
roachnigga's Avatar
roachnigga
It threw me off too, but 837, was alot of help.... Dude, wish u was out here on the AUUTO!!! itz a blast...
soon im about to go stage 2...but im researching do i have to get a Bigger Intercooler (Perrin) and Walboro's fuel pump wit a regulator for i can run rich...
I'm not sure... so, i also, before the stage 2, about to buy an A/F gauge and oil temp. I was thinkin' EGT but im not really familar wit that type of component. plus, the whole Tap & Drill thing is not my line of Work....
Peace
[sm=smiley16.gif] [sm=smiley34.gif]
Old Mar 31, 2004 | 08:47 PM
glhs837's Avatar
glhs837
There will be a novel later. Cliff notes for S2
Bigger cooler = not needed ynless you plan to go past 300 whp S2 stock = 265/280 street/race gas.
Fuel control NOT required for S2, see above
Gauges not really needed, I'll be adding two myself. I'll post a link later for a great gauge install how-to that puts them next to the boost gauge in factory mounting cups. Along with the PVO approved location for an EGT probe.
Old Mar 31, 2004 | 09:49 PM
glhs837's Avatar
glhs837
http://mysite.verizon.net/ghardeen/how_to.pdf
Right click and save as, the net is a fickle storage medium
Unless you want folks to see what your packing, I like this best
S2 will handle all engine mamngement functions. So it will not let you run lean. Your main desicion will be with Turbo Toys or not.
