Overheating
Old Apr 1, 2004 | 10:40 AM
  #21
roachnigga's Avatar
roachnigga
Default RE: Overheating
Thanks for da Info... Im goin for the Toys... about the inter cooler thing, wit the stage 2 installed, ill be runnin' close to 3 in or around 292.... so what u think, dude? Cooler yes or no
One
Old Apr 1, 2004 | 12:25 PM
  #22
glhs837's Avatar
glhs837
I gotta ask, what makes you think you'll be that high? As far as the cooler, unless you plan on playing with the boost yourself, it MIGHT be needed, but only the turbo swap folks have seen any real gains with them. It's tied in with how well the stocker flows. Look at your end tanks closely. If you are not familiar with CFD (computational flow dynamics) it might not make sense how a tank half the size could be as efficient at cooling the intake charge.
CFD uses supercomputers to model airflow, NASA uses it to predict airflows over aircraft surfaces at ridculous speeds. Like Mach 7 or so. Dodge has the capability to use this kind of tech. there have been sniffs that the PVO guys got their hands on one of the aftermarket coolers and flowtested it. It lost.
I'm taking their word that you won't need bigger than the stock unless you go with a bigger turbo than Stage 3. Same for fuel flow. I'm so up on this because I'm on the list for the 18th kit to be shipped. I've scoured every possible souce for info. And as andy found out, I can find some VERY good sources
