Oil Catch Can
Old Jan 9, 2006 | 11:39 PM
MikeyLittle's Avatar
MikeyLittle
Default Oil Catch Can
I have never said that i was a "car" guy. Mechanics wise that is, so i expect a few chuckles at my next question. What is a Oil Catch Can and what is it used for, i mean the name is self-explanitory but why is it something needed on our srt4s? And is it something that is needed?
Old Jan 9, 2006 | 11:57 PM
rx8driver's Avatar
rx8driver
Default RE: Oil Catch Can
ORIGINAL: MikeyLittle
The turbo on the srt-4 blows oil past the pcv valve eventually causing oil build up in the intake, intercooler, throttle body, etc. and at worst reaching the spark plugs causing them to fowl. So in short you need a occ to catch this oil before it gets to these areas. See the $20 occ sticky at the top. I have it and it works great. It is a cheap alternative to an $80 name brand. The occ is a must.
Old Jan 10, 2006 | 12:21 AM
MikeyLittle
thank you, that clears it up a lil bit for me. i'll def. look into the occ you were talking about
Old Jan 10, 2006 | 02:47 AM
dustyloins's Avatar
dustyloins
Hall of Fame Member
You'll end up shopping at Pep Boys, and either Wal-Mart or Lowes or Home Depot and spending maybe $22-23 dollars, tops. The actual "can" will be a Campbell Hausfeld Air Compressor Air Filter and added tubing and fittings and clamps. Remove the white filter element from the CH air filter for better performance......total assembly time, maybe 5 minutes. Total install time, maybe 7 minutes, even for a geek like me.....
And YES, you DO need one!!!! Here's mine after the install WITHOUT the clamps installed......
Dusty
[IMG]local://upfiles/894/D341C2DCFE574B2A9EBA1CB454A60E51.jpg[/IMG]
Old Jan 10, 2006 | 12:13 PM
BigE's Avatar
BigE
I found my oil dripping from the lower air box the other day a thought, Oh that's what the OCC is for. I to will be shopping at Home Depot soon. Dustyloins thats for the great pic, it helped a lot!
Old Jan 10, 2006 | 05:11 PM
MikeyLittle
ok cool thank you dusty, now when i do get one how do i empty these things out, i dont just open the bottem and let it pour out do i lol, if thats the case your goin to be see'ing me parked on a couple of different lawns lol
Old Jan 10, 2006 | 06:02 PM
rx8driver's Avatar
rx8driver
The bowl that collects the oil on the mini air filter ($20 occ) unscrews.
Old Jan 11, 2006 | 02:16 PM
got boost?'s Avatar
got boost?
What type of hose and clamps did you guys use to connect your OCC to the PCV?
