Turbo Timer
Old Mar 23, 2006 | 03:32 AM
mxrnick's Avatar
mxrnick
Default Turbo Timer
i got a GReddy Full Auto Turbo Timer and i installed it with instructions i got from some post on this site. i was wondering if anyone here has the GReddy turbo timer and if there is some trick to getting it to work. i have never had a turbo car and i am not sure how the turbo timer works. i also bought a manual boost controller off of Ebay and i have no idea at all on how to install it. i have recieved different drawn diagrams and instructions for other cars, but i would really like it if some one had like and actual picture of the MBC installed. if anyone can give me any help on either install it would be greatly appreciated.
Old Mar 26, 2006 | 06:26 AM
BigMac's Avatar
BigMac
Default RE: Turbo Timer
You can download the TT manual here.
As for the MBC, if you're stock you want to cut the vacuum line to the WGA, reconnect it using a tee fitting, and connect the vacuum line from the MBC to the third barb on the tee.
Hope this helps.
Old Mar 26, 2006 | 04:09 PM
w4rR1oR's Avatar
w4rR1oR
i havent installed a tt in my srt-4 because i put it in a garage with no windows and has no vents witch air can come in a n out and theres a water heater in the garage and im not sure if i leave the car on the fumes might cause a fire
Old Mar 27, 2006 | 09:31 PM
nicks2kes's Avatar
nicks2kes
i just bought the greddy turbo timer the other day, does anybody know if it comes with the instructions, my computer is mad slow and wont load adobe.
Old Mar 27, 2006 | 10:18 PM
jac05srt4's Avatar
jac05srt4
mine came with instructions but they were in japanese. the best bet would be downloading adobe overnight if it is that slow. also i had a hard time getting mine to set times, but if you have any questions email me and i will fill you in on what i learned so far.
Old Mar 28, 2006 | 01:32 AM
mxrnick's Avatar
mxrnick
for the MBC there are 2 fittings. one goes to the WGA (right?) and the other comes from where? is my GReddy turbo timer supposed to be able to turn on when the key is out of the ignition? my TT doesnt keep the car running. i need your help, please.
Old Mar 28, 2006 | 01:48 AM
w4rR1oR's Avatar
w4rR1oR
im sure you dont have to leave the car in gear......so it wont turn off when you releas the clutch...but thats just my opinion....and i dont have a tt on my....ohhh yeah about my tt...would it be bad to leave the car on for a while near a water heater with an open flame.. in a garege with no air vents,.....
Old Mar 28, 2006 | 03:56 AM
scottw03's Avatar
scottw03
Ok, first off, use the HOW-TO section on SRTforums.com. Has tons of, well, How-tos that you can use to install basically anything in your car.
Second, inorder for your TT to work right when you go to turn your car off it has to be on. I am sure most have multiple settings like Off, High Time, Low Time, voltage, boost, temp, etc... Just make sure it isn't in the off position. When you go to turn your car off make sure the car is in neutral. otherwise you will stall out. Just leave your E-brake on.
Know that your stock alarm system will not work with this setup. You can lock your car door but the alarm will not engage. when the car turns off then you can click the button on the key fob and it will engage.
Really, you only need it if you run the car hard. I use it in the morning to warm the engine up so I don't have to leave my key in the car. Or when I drive the car hard when coming home on the highway, I might let it sit for like 2 mins. Also, when I go out to street tune the car since it is running hard when you are testing it I will use it since the Turbo is getting really hot during those times.
Oh, just incase you try this, SRTforums.com is currently down, something with the server but when it comes back up there is a TT wiring How to on there. Also, if you go to cardomain.com, there is a wiring how to on my page. Just go to rides, and search for my name scottw03. I think it is the 3rd page is the HOW TO. it is for the Blitz FATT DC TT but it uses all the same wires from the car.
Good luck
Old Mar 28, 2006 | 05:29 AM
moparman04's Avatar
moparman04
if you park it and turn it off before you pull the ebrake up it will not activate
Old Mar 28, 2006 | 11:08 PM
mxrnick's Avatar
mxrnick
can anyone help with my MBC installation problem?
What does "and connect the vacuum line from the MBC to the third barb on the tee." mean?
where does the vacuum line come from?
