PLEASE HELP!!!!!!!!! EBC MALFUNCTION!!!!
Old Mar 27, 2006 | 02:23 AM
winniep's Avatar
winniep
Default PLEASE HELP!!!!!!!!! EBC MALFUNCTION!!!!
I installed my Greddy Profec B spec II this weekend and now my car won't boost past 5 psi! I used the forum instructions step by step to hook it up. Shouldn't my car still boost what it was boosting before with it turned off? Lilsparkplug, don't you have a Greddy with a stg 2 WGA? If you or anyone else who has this setup could buzz in it would be greatly appreciated. I hooked my vac lines in the following...... Greddy >>>> T into boost guage. NO >>>> T into Green turbo hard line. COM >>>> Stg 2 WGA (hooked up just like stock). Capped stock WGA line. Also capped CAI and ran a catch can while I was at it. Oil had gotten to the turbo so I had to fix it. My car is in such bad shape I'm not even going to drive it until this next weekend when I get a chance to work on it. If anyone knows anything about my problem, PLEASE, I want to drive my baby! On a good note, the apexi turbo timer went on without a hitch and works great!
Old Mar 27, 2006 | 12:08 PM
rx8driver's Avatar
rx8driver
Default RE: PLEASE HELP!!!!!!!!! EBC MALFUNCTION!!!!
ORIGINAL: winniep
Yeah it should boost off of the wastegate setting with the EBC off. You have it hooked up right so it has to be a boost leak somewhere. Did you zip tie all of the vaccum lines? Check for leaks, especially the line you capped. Maybe it is something to do with the wastegate...Lilsparkplug should have better advise since she has the stg. 2 wastegate.
Old Mar 27, 2006 | 03:24 PM
LilSparkPlug's Avatar
LilSparkPlug
Yes I do have the EBC w/the S2WGA, it sounds like something isnt hooked up right to me. Or something just isnt tight enough.
Okay I put all of my settings on my EBC to 0, and its only pushing 5-6 maybe 7 lbs of boost. Thats what the wastegate is currently pre-loaded at, what Im doing, and what you should do also, is get the wastegate to 0 pre-load meaning it doesnt boost anything at all, then allow the EBC to control your boost.
Old Mar 27, 2006 | 07:09 PM
winniep's Avatar
winniep
What are you using as a boost source to the unit? The boost guage line?
Old Mar 28, 2006 | 02:08 AM
rx8driver's Avatar
rx8driver
ORIGINAL: winniep
I T into the boost gauge line just like you did and mine works fine.
Old Mar 28, 2006 | 02:28 AM
WhtLightning's Avatar
WhtLightning
EBC, SRI CAI, PCM, STS, FMIC, AYGWTDM,... is it just me, or do we need an acronym dictionary on here!! (yes Word, I'm hoping for some back-up here!!!)
Old Mar 28, 2006 | 02:54 AM
LilSparkPlug
EBC = electronic boost controller
SRI = short ram intake
WOT = wide open throttle
CAI = cold air intake
PCM = powertrain control module
OBD = On-board diagnostics
STS = short throw shifter
FMIC = front mount intercooler
SEE = side exit exhaust
MBC = manual boost controller
yeah theres more too...
Old Mar 28, 2006 | 03:35 AM
WhtLightning
I'm sure there is, but you added WOT, ODB (formerly known as 'Old Dirty Bastard'... in contrast to popular belief [and what I'm sure you're all thinking] not me.... well maybe not me LOL!), SEE, and MBC.
Not that I'm not a fan of getting more than I asked for, ... just thought I needed to point that out.
{What a Pr**k}
Old Mar 30, 2006 | 01:42 AM
LilSparkPlug
Here's one of my "T"s I have two, the other T's into the boost gauge line.
