Code I don't understand
Old Apr 18, 2006 | 01:19 PM
turbobaby18's Avatar
turbobaby18
Default RE: Code I don't understand
Well my coolant is low because I need to find a dealer for Mopar antifreeze, could this be the problem?
Old Apr 18, 2006 | 01:49 PM
LilSparkPlug's Avatar
LilSparkPlug
I wouldnt think that would cause it. That would just cause the car to overheat if it was too low. Theres no dealers around your area that you could take it to?
Old Apr 18, 2006 | 02:12 PM
rx8driver's Avatar
rx8driver
ORIGINAL: LilSparkPlug
Yes it does include the 05s as well. The OBD codes aren't neccessarily vehicle specific.
So Im assuming you didnt touch anything under the hood, cause this has me confused out the *** right now. The only other thing it could be is cold weather or a small vac leak on the factory WGA line (Black line).
Like LSP said...a leak in the WGA line would be my guess...I've seen this in a wrx where there is a leak in the wastegate line and it throws an overboost code. So check that line.
Old Apr 18, 2006 | 03:23 PM
turbobaby18
Yeah I just went to the dealership but to make a appointment I have to wait for my registration to come in. Here is my situation- I bought the car used from a Ford dealer in New Jersey and I live in New York. It has only 12,000 miles on it. When I go to tell them the problem are they going to ask me any questions to try and trick me out of the warranty. The reason I ask this is because I also wanted to have my tranny checked because sometimes when I put it in 2nd or 3rd it feels sought of ruff to do.
Old Apr 18, 2006 | 05:45 PM
LilSparkPlug
The tranny is very rough shifting 2-3 and 3-2, its just how the T850 is. However if you can't get it into gear at all, if it grinds when you release the clutch, pops out of gear, or is stuck IN gear, thats definitely a transmission problem.
Since its not cold where you are, then its definitely the black line running off the wastegate, its the second or third one down on the solenoid closest to the battery.
Old Apr 18, 2006 | 06:44 PM
turbobaby18
I just checked the codes again and saw this code too.....
P0441-EVAP PURGE SYSTEM PERFORMANCE
Old Apr 18, 2006 | 06:45 PM
turbobaby18
About the tranny, the gear always goes in its just not smooth like my civic, thats why i was getting worried. But thanks for the info!
Now just got get these codes cleared.
Old Apr 19, 2006 | 03:10 AM
WhtLightning's Avatar
WhtLightning
I didn't see this question asked on this thread, but these cars are notorious for bad boost gauges. What does your boost gauge read when the engine is off?
Old Apr 19, 2006 | 05:40 AM
turbobaby18
When the car is off it sits at 0. I disconnected my battery for a while and then drove th car and the light stayed off. I'll see how long this last.
Old Apr 19, 2006 | 04:54 PM
LilSparkPlug
The 441 is probably a bad gas cap.
Heres possible causes:
Good Trip Equal to Zero
Intermittent Condition (doesnt happen all the time)
Checking EVAP Purge Solenoid Functionality
EVAP Purge Solenoid Vacuum supply (Gas cappage)
And on the OVerboost code, you should have your entire solenoid pack checked for a vacuum leak because that is more than likely the cause. Dont just get rid of the codes, have them checked out, unless your 100% positive it isn't hurting the vehicle and nothing is wrong. I.e. a P0420 code on an S0 car with no Cat, you know that its a cat code, and you can erase it and have peace of mind knowing that theres nothing wrong with the car.
Never erase them, always check them, or have them checked out.
