slight rattle at idle
Old May 17, 2006 | 06:20 PM
flamingpinhead's Avatar
flamingpinhead
Section Moderator
Default slight rattle at idle
While on the subject of maintenence, there is a slight tap or rattle at idle. could this be that the valve timing is a little off? I changed out my oil (&tranny fluid) and its still there. not very noticable but I am paraniod about my cars. in any case, i guess ill call up the dealer and inquire about it regardless. i know the 2.0s all have a little bit of a tap at idle after they are broke in... but the 2.4 also???
Old May 17, 2006 | 07:54 PM
RIPSIGUY's Avatar
RIPSIGUY
Default RE: slight rattle at idle
Does it go away when you depress the clutch to the floor? Alot of these trannies have gear rattle in neutral, fully warmed up. (That is normal. )
Old May 17, 2006 | 08:19 PM
flamingpinhead
Section Moderator
actually you cant hear it when inside the car, only when by the engine, it sounds like its coming from more of the valve side of things
Old May 18, 2006 | 01:31 AM
Four Banger Anger's Avatar
Four Banger Anger
these srt-4's are loud to begin with, alot of stuff shakes and rattles, i was told big gears make for alot of noise and it could just be the injectors firing and making noise.
Jordan
Old May 18, 2006 | 03:33 AM
LilSparkPlug's Avatar
LilSparkPlug
Theres a TSB to champher the cam caps on 04s and 05s. Take it in and have that done, the noise should go away.
Old May 18, 2006 | 05:22 AM
Four Banger Anger
what does TSB stand for?
Jordan
Old May 18, 2006 | 01:52 PM
LilSparkPlug
Technical Service Bulliten.
Something that happens to alot of the cars, but isn't dangerous enough or serious enough to warrant a recall on it. I dont have the exact TSB number in front of me, but I am 100% positive there is one.
Old May 18, 2006 | 02:07 PM
flamingpinhead
Section Moderator
ill research it, thanks
Old May 18, 2006 | 05:24 PM
Plan B's Avatar
Plan B
Could you post what you find?
Old May 19, 2006 | 02:47 AM
LilSparkPlug
Pm Paul, RIPSIGUY, he can give you the exact service bulliten on it. I had it done to my car for the same kind of irregular tapping/snapping noise. After that it went away
