? about install
Old Jun 13, 2006 | 02:09 AM
Polishguy33's Avatar
Polishguy33
Default ? about install
I just installed my mopar bov. I like how it sounds but now it is only boosting 6 psi. This might be because i have a bad boost guage right now. it was boost 10-11 psi before thought. do you think i tightened the bolts down to tight because it said to tighten to about 63 in. pounds i think. I also acidently drove around the block with the air hose to the turbo off.
Old Jun 13, 2006 | 01:47 PM
Valo2170's Avatar
Valo2170
Default RE: ? about install
that never happend to me but try this! Reset the battry 1st,than if that dont work take it to the dealer and tell them what it is doing.Just dont tell them how you think it might off happend.I dont see it being because you made the bolts to tight.I Would think that would help with not having a boost leak.What did it feel like befor?Did it feel the same way as it does now?It might just be a bad boost gauge,but you did say that it just now did that.Reset it 1st then see what it does then reply back.I have a after market bov now so i dont have the mopar anymore.Maby if i did i could help more.
Old Jun 13, 2006 | 02:21 PM
Gump's Avatar
Gump
your turbo should be just fine if you drove it with out the intake on. compressor blades are easy to bend but i highly doubt a trip around the block will do anything.
sounds like you have a very bad boost leak. does it make a leaking/whistle sound when you boost? did you use sealant on the install?
Old Jun 13, 2006 | 05:04 PM
Polishguy33
It feels pretty much the same but now it wont spin the tires if i go wot in 2nd. It dosent whistle when i get in boost and i didnt put any sealant on it.
Old Jun 13, 2006 | 07:01 PM
ericorange05's Avatar
ericorange05
What does your boost guage read while the car is not running? Also you might want to check to see if the gasket is not crushed or if its not centered on the BOV it will cause a leak. Check all hoses on the intake and vac. lines, could be off or loose.
Old Jun 13, 2006 | 07:25 PM
Valo2170's Avatar
Valo2170
whos does that?
Old Jun 14, 2006 | 01:00 AM
dustyloins's Avatar
dustyloins
Hall of Fame Member
Permatex Hylomar HPF sealer.....just a little dab will do ya'......
Dusty
Old Jun 14, 2006 | 07:47 PM
street demon's Avatar
street demon
I HAVE THE SAME PROMBLEM I JUST DROPED IN MY MOPAR BOV AND THE SAME THING HAPPEND TO ME. NOW 3RD AND 4TH GEAR ONLY BOOST UP TO 11PSI SOMETIMES 12PSI. I HAVENT FOUND A WAY TO FIX IT IF YOU DO LET ME KNOW WHAT YOU DID. BUT LIKE ME I JUST THINK ITS GOING TO BE A DUMB BOOST LEAK.
Old Jun 15, 2006 | 04:56 PM
Polishguy33
Im just going to try the sealer when i get some time to take it apart. ill post back here and tell you if it works. it should fix the problem.
