$20 OCC question
Old Jun 26, 2004 | 05:31 AM
Gump's Avatar
Gump
Default $20 OCC question
i installed a $20 occ this morning and from the pics ive seen the arrow on the top of the filter points towards the rear of the car. i used clear tubing and ive noticed that the oil is in the tube leaving the occ but not on the other side, there is quite a bit of oil in there for about 40 miles and was wondering if that was the way its suppost to be?
Old Jun 26, 2004 | 07:20 AM
Bildo's Avatar
Bildo
Default RE: $20 OCC question
This is the page I followed to install my OCC. I have my arrow pointing toward the front of the car but on these pics it is pointed toward the back. I don't know if it makes much difference, but I'm pretty sure mine is working.
http://srt4.thebatanesislands.com/my...an_060203.html
Old Jun 26, 2004 | 08:40 AM
Gump's Avatar
Gump
Thats the sight i used too....
Old Jun 26, 2004 | 04:21 PM
dustyloins's Avatar
dustyloins
Hall of Fame Member
Mine is catching plently of oil and the arrow is pointing to the front, in the direction of the throttle body.....[&:]
Old Jun 27, 2004 | 01:19 AM
byebye's Avatar
byebye
Amazing isn't it? If I'd known ther was that much going in I would have done it earlier.
Old Jun 27, 2004 | 01:38 AM
dustyloins's Avatar
dustyloins
Hall of Fame Member
For sure! Kinda makes you wonder what PVO was thinking.....
Old Jun 27, 2004 | 07:36 AM
Gump's Avatar
Gump
Y does it do it in the first place? and not come with a stock OCC?
Old Jun 27, 2004 | 06:58 PM
71RoadRunner's Avatar
71RoadRunner
No matter how you have it mounted, arrow facing forward or back, as long as the hoses are hooked up in the right direction you will be fine. Actually you will be fine either way, but it seems to flow a little better going in the right direction. The hose coming from the PCV valve should be going into the OCC in the direction of the arrow and the arrow should then be pointing to the outlet hose that goes where the PCV hose hooks into the hard plastic line. Then everything is fine.
