Newb looking into car and modding
alright well i am def a lot more interested in performance. with the mods i have listed will a map clamp help out any with my et and just straight out performance. like i said the boost is 19psi, 14@redline. how should i adjust or should i even get a map clamp? also could someone please give me more information on them and explain what they do exactly!
If this is what I think it is and does what I think it does, then [sm=forgetit.gif][sm=noooo.gif][sm=badidea.gif][sm=nothatway.gif]. If it tricks the PCM into "seeing" less boost than it is actually putting out, your going to run it into a lean condition one too many times and your engines gonna go nuclear. They used this trick on the '80's turbo cars and while some squeeked by with doing this, others ended up walking home with rather expensive repair bills that the dealerships won't cover.[:@]
If you want to do it right you will also need to add more fuel to the mix to keep it from running lean. If this is the case, tread lightly down this path.[sm=smiley3.gif][sm=smiley24.gif]
