NGK Plugs
Old Oct 18, 2006 | 07:43 PM
Burnnout's Avatar
Burnnout
Default NGK Plugs
Anyone running an iridium ngk plug ? ... if so which one ? ... all I could find was a NGK Iridium 2314... looking for an iridium so I don't have to deal with the 4306's replacement issues.
Old Oct 19, 2006 | 07:38 AM
talisman's Avatar
talisman
Default RE: NGK Plugs
Burnout, I just bought the stock heat range NGK Iridiums from modern Performance. They should be here today.
NGK Iridium Spark Plugs Stock heat range (LZTR5AIX-13) and colder (LZTR6AIX-13) available
$29.99 set of 4
Old Oct 19, 2006 | 11:17 AM
Burnnout's Avatar
Burnnout
Happen to know what the part number is on those ? ... probably either 2314 or 2315... let me know how it runs
Old Oct 19, 2006 | 07:37 PM
SRT_YA's Avatar
SRT_YA
Actually, he gave you the part number. You are asking about the "stock number"... but...
Some people are closing the gaps on these plugs (from the 1.3mm gap down to about 1.0mm).
In stock trim the stock heat range (LZTR5AIX-13) is fine with no gap mod's typically.
Old Oct 19, 2006 | 07:55 PM
talisman's Avatar
talisman
Burnout,
turns out the part number translates to a 2314. I'll let you know how it goes. Is there a reason you're avoiding the 2314's ? People having problems with them ?
Old Oct 19, 2006 | 08:20 PM
Burnnout's Avatar
Burnnout
no i'm not avoiding them at all..... just haven't seen any feedback on them.... ya sorry SRTYA you're right but i always go with the stock number when ordering plugs and what not for my shop ( I work in a nissan dealership and all they use is ngk's )
Old Oct 20, 2006 | 01:34 AM
LilSparkPlug's Avatar
LilSparkPlug
These car's don't like the iridiums. Go with the Denso ITL's or the NGK 4306's
Old Oct 20, 2006 | 02:57 AM
`71RR383SRT4's Avatar
`71RR383SRT4
I put the NGK #4306's in and gapped then to .045. And after I fixed my stumbling problem with a new set of wires. I think you should do what LPS say's. She knows her ****! Thanks again LPS
Pops
Old Oct 20, 2006 | 03:18 AM
Booost Babe's Avatar
Booost Babe
The NGK's work great as do the Iridiums- it's all about preference. (sp?)
Old Oct 20, 2006 | 10:45 AM
SRT_YA's Avatar
SRT_YA
ORIGINAL: LilSparkPlug
I'd have to disagree some here... but... to each their own. My car runs great with heat range 6 (thats "colder") iridiums.
typically Iridiums have better ignitability, extended life, and require lower sparking energy to fire than a standard nickel plug
