ATTN: 300 HP club
Old Nov 4, 2006 | 12:31 AM
Engine Hunter's Avatar
Engine Hunter
Default ATTN: 300 HP club
I have a few questions for you.
1) Baseline (do a dyno run stock?)
2) What parts/tuning did it take?
3) HP and Torque numbers with peak RPMs (a dyno graph would be nice, same dyno as baseline run would be even better)
I don't own an SRT-4, but the engine is looking like the pick for a project car I plan on starting this spring... If at all possible, I would like to stay at relatively low boost (20 psi?) since I may not be able to fit a large IC. I realize it will be more expensive to do it that way, but it may be required. And lastly, what are some good aftermarket sites for tuning SRT-4 motors? Thanks
-Tim
Old Nov 4, 2006 | 11:16 PM
gkg43's Avatar
gkg43
Default RE: ATTN: 300 HP club
im not sure if it worked..but i uploaded my dyno sheets.. given, this is a **** load more than 300hp, but it should give you an idea...if you want to know my list of mods, see my listing subject: "what to do with 500hp", its just a few postings under yours in the "drivetrain" section...
[IMG]local://upfiles/46919/E659AAE8E3694C60B6EDA0FE4E64DEA5.jpg[/IMG]
[IMG]local://upfiles/46919/0C8062462A5145D49136955BAC7B68F7.jpg[/IMG]
Old Nov 4, 2006 | 11:18 PM
gkg43's Avatar
gkg43
i forgot to mention... the first run (the one on top) is at 22psi on street gas...it ran 411whp..the bottom run made 486whp at 28psi on race gas...
good luck
Old Dec 27, 2006 | 03:04 PM
hositup's Avatar
hositup
Where do I go to get a srt4 engine?
Old Feb 22, 2007 | 01:53 PM
wannasupra's Avatar
wannasupra
from AMS. ~2200 bucks for a built short block, with wiseco pistons, eagle rods, no balance shafts, blueprinted and balanced bottom end, add another couple hundred for ARP studs top to bottom. you can get em to bolt on their stage 3 race ported head, also with ARP studs, for another 1800 bucks. only a little more expensive than stock. and they have various component upgrades availible as well. i made ~330 whp at 15psi on a 50 trim with 9:1 afr's. ran a 13.7 @ 106, not impressive, but when you consider the stock srt's at the same track were barely trapping 100 and crossing the lights at 14.3 or so, it's not that bad. anyway, a bigger turbo nets you mileage as well, it's not spooled all the time, so you don't suck gas down. i picked up 3 mpg from a 3 inch mandrel bent exhaust, and another 3 from the big turbo, and that's around town mileage, i get near 30 on the highway.
Old Feb 22, 2007 | 10:59 PM
Burnnout's Avatar
Burnnout
Something is not adding up there.....
Old Feb 23, 2007 | 04:17 AM
wannasupra's Avatar
wannasupra
i know, it was running like ****. bithlo is known for having terrible grip. a buddy of mine just moved down here from ohio, he runs a 9.89 on the bottle (built 406, trans brake, stall converter, heads, cam, etc) and the best pass he could manage at bithlo was a 10.5. the track is slow.
Old Feb 23, 2007 | 01:14 PM
redevil's Avatar
redevil
damn 13.7? i ran a 13.5 with just wastegate and exhaust.Why don't you turn the boost up a lil bit?
Old Feb 23, 2007 | 02:14 PM
PSI Chick's Avatar
PSI Chick
ams is on crack with what they charge. and no one should be using arp studs on an srt. i'm surprised that aem wouldn't use a better product.
Old Mar 23, 2007 | 05:01 PM
YeahItsAHemi345's Avatar
YeahItsAHemi345
ORIGINAL: wannasupra
Bithlo FTL. 14.3 @ 105 14 second club FTW-"Where time slips don't mean ****!"
