bov releasing too much pressure!?!?!?
Old Dec 20, 2006 | 04:42 PM
  #21
redevil's Avatar
redevil
Default RE: bov releasing too much pressure!?!?!?
look man....I suggest you eaither google it out or go to srtforums.com and ask those guys there, they have been around longer and dealt with every little problem you might think of.Ask them about the boostleak tester..they'll be more than happy to help you out and answer any other questions.And i'm sorry I can't tell you if it's ok to back those bolts off because I've never put on a mopar bov, but listen to my advice and ask the guys at srtforums
Old Dec 22, 2006 | 06:11 AM
  #22
PSI Chick's Avatar
PSI Chick
if it's over tightened it will just cause air to come out through a leak. since it's a plate, it's very easy to do this. hence why it's called a boost leak.
here's instructions on how to build and use a boost leak tester. it's not that hard...
http://www.vfaq.com/mods/ICtester.html
Old Dec 22, 2006 | 12:05 PM
  #23
04blksrt's Avatar
04blksrt
thank you so much psi...that will be a nice project for me to do this weekend.
Old Dec 24, 2006 | 04:06 AM
  #24
71RoadRunner's Avatar
71RoadRunner
ORIGINAL: 04blksrt
lets say you did overtighten. if you go in and back the bolts off alittle will it flex back out to straight?
If it isn't bent much then that should work, but if it's bolted way too tight it will be bent and loosening won't help. If it is bent too much then you will need to remove it and flaten the flange back out and reinstall it.
Old Dec 24, 2006 | 11:54 PM
  #25
04blksrt's Avatar
04blksrt
alright i did some work on it today. its acting like it will seal and air wont get out until i let off the gas to change into 2nd gear. when i let off the gas its like the flange is opening up and staying open and its constantly releasing the pressure. then if i coast for a while it will seal itself back shut and start working right (not letting the pressure out) until i let off the gas again. so i replaced the factory valve with a different one (tihnking it night be in the spring or seal) and had no affect. has anyone heard of a defected mopar plate? i know that everything is on right, gasket is lined up, bolts are tightened....anyone have any ideas. and redevil dont get too frustrated with me
