Having Problems
Old Dec 26, 2006 | 01:46 PM
  #31
redevil's Avatar
redevil
Default RE: Having Problems
hey psichick what do u think about raptor bovs...? modernperformance has pretty good deal on one...they sell the bov with hardpipe and block plate for $300
Old Dec 26, 2006 | 01:48 PM
  #32
PSI Chick's Avatar
PSI Chick
i've installed one raptor and it was a pain in the ***! sounds ok though. only issue after the install is about three months later it started leaking from the bov itself and a replacement was needed (no warranty btw). not sure if that was an isolated case or not, but that's been my only experience with it.
Old Dec 26, 2006 | 01:55 PM
  #33
redevil's Avatar
redevil
that sucks.....what bov you got on now?
Old Dec 26, 2006 | 01:59 PM
  #34
PSI Chick's Avatar
PSI Chick
i've got a greddy rs on (had a s before that) but i'm switching to a turbosmart supersonic soon.
Old Dec 26, 2006 | 02:01 PM
  #35
04blksrt's Avatar
04blksrt
i already took off the rice plate and put it back stock with a different factory valve. when i was running the boost leak detector yesterday it was leaking from the third bolt side of the stock converter plate. i know that its tight enough and its not near as bent as other ones i have seen so i dunno. the factory plates didnt come with a gasket did they? i cant remember
Old Dec 26, 2006 | 02:02 PM
  #36
PSI Chick's Avatar
PSI Chick
no there's no gasket. the edges probably bent when you took it off, it's a common problem. just need to get a replacement.
Old Dec 26, 2006 | 02:35 PM
  #37
04blksrt's Avatar
04blksrt
ok so i told yall that i broke the vacuum line running off the exhaust side of the turbo. theres a port right beside the factory bov that has a rail where the blue wire is conncected. does anyone know if this is a check valve cause when i TRIED to fix it i just replaced it with a hose and a conector. im usre everything is tight and didnt feel any air coming through it when i put the boost leak on there but i am concerned that its supposed to be a check valve as opposed to just a regular vacuum. i know that my problem is something stupid and simple but i feel like i have exhausted every possible route tryin to fix this situation and i am completely and utterly dumbfounded and confused and pissed and clueless and any other emotion that yall can think of to add to that
Old Dec 26, 2006 | 03:51 PM
  #38
redevil's Avatar
redevil
lmao...relax bro.....sit back....have a smoke and then get back at it!!!!!!!
Old Dec 26, 2006 | 05:11 PM
  #39
04blksrt's Avatar
04blksrt
so you got any idea of what vac. line im talkin about? i cant remember the correct terminology for it but its the rail the blue vacuum hose connects to. that (the blue line) is actually the part that broke off. now this was causing my car to idle funny but was getting all 15 psi. now the car idles fine and is not boosting worth a ****. i even had a srt mechanic look at it and i know that he is more than qualified. hes got 6 srts laying around and hes the guy that everyone around here takes their car to when its fouled up.he replaced my factory valve with a different one that seemed to be sealing better than mine and it had no affect. maybe i can steal that vacuum cluster off one of his junk cars and see what that does
