Stage 1 Upgrade
Old Mar 14, 2007 | 07:36 AM
Aceburner's Avatar
Aceburner
Default RE: Stage 1 Upgrade
True... and if you really dont think your going to use the Toys if you end up racing it at the track or whateverthen dont get it. Me, for example, I'm not big on racing now BUT, I may get into it later when my car gets where I want it to beso I'm getting the option just in case. There is another option if you dont want to pay that much. http://www.srtforums.com/forums/showthread.php?t=199101Check it out, it's works great for what I hear and saves a lot of money.
Old Mar 14, 2007 | 01:53 PM
silverblacksrt4's Avatar
silverblacksrt4
you really dont need to get the toys.. i mean if u are really going to be into racing you'll probably get more upgrades and Maybe a new turbo?? but yeah i heard problems with the toys and its not worth the extra dough!!!
Old Mar 15, 2007 | 12:47 PM
monstab757's Avatar
monstab757
Is the stage 1 pcm hard to replace? Or do you just disconnect/connect a few wires?
Old Mar 15, 2007 | 01:30 PM
monstab757's Avatar
monstab757
Well actually I'd be installing a Stage 1 PCM not replacing it. How difficult is this?
Old Mar 15, 2007 | 01:52 PM
silverblacksrt4
no difficult at all.. it is right next to the left headlight.. you undo some stuff and it comes out easy!!
Old Mar 15, 2007 | 02:13 PM
PSI Chick's Avatar
PSI Chick
there is absolutely nothing "wrong" with stage 2. the issue with the ic sprayer is that it leaks, nothing that a little glue won't fix. DAB is a great feature, more than any mbc or ebc can possibly do. plus s2 has been known to be able to hold HOM with 93 and w/i, so even if you don't use race gas it's still possible to benefit from the little red button.
if you want to go the s2 route though i would suggest getting a used s2 w/toys ecu and getting the toys box from n2mb. it works out being much cheaper that way.
Old Mar 16, 2007 | 01:16 PM
hemi4x's Avatar
hemi4x
The stage 1 is the best bang for the buck, I use stage 1 ecm, injen intake, Mopar catback, stage 2 wastegate set to 15 psi and damn car is fast, alot faster than the satge 0 set up. I have read that the stage 1 when moded like mine is faster than the stage 2, dyno has proven this.. like I said what I have read on the SRT Forums.
Old Mar 16, 2007 | 02:04 PM
monstab757's Avatar
monstab757
Thanks hemi4x! Thats the kind of straight answer I was looking for. BTW what are the 3 bar MAP and TIP sensors for that come with the Stage 2?
Old Mar 18, 2007 | 09:31 PM
monstab757's Avatar
monstab757
Does anyone have a "How To" on installing a Stage 1 pcm. I'm not too mechanically inclined but I really wanna do it myself. Also I heard the factory directions that come with it aren't to straight forward.
Old Mar 18, 2007 | 11:47 PM
aiverson's Avatar
aiverson
I just put my s1 last week. it's easier to take the bracket off that the pcm mounts to. also here is a video about s1 vs s2. with the right mods I believe s2 can be really fast.
http://www.youtube.com/watch?v=SCOkERnx7yE
Tony
