OCC.../TURBO TIMER....??
Old Sep 1, 2004 | 12:15 PM
bellosiciliano18's Avatar
bellosiciliano18
Default OCC.../TURBO TIMER....??
HEY EVERYONE.....IM LOOKING INTO FINALLY GETTING A OCC FOR MY CAR BECAUSE EVERYBODY IS SAYING THAT ITS A "MUST" SO I DEF GONNA GET IT, BUT WAS WOUNDURING WHICH IS THE BEST ONE THEY MAKE AND ALSO EASEST ONE TO USE....COMMENTS ABOUT YOURS IF YOU HAVE ONE WOULD BE GREAT ALSO........
AND.....
I ALSO WANA GET A TURBO TIMER, BUT DO I NEED ONE FOR A STOCK SRT OR SHOULD I GET IT ANYWAYZ.....AND I HEARD GOOD THINGS ABOUT THE GREDDY TURBO TIMER....ANY SUGGESTIONS.....? THANKS!
Old Sep 1, 2004 | 12:37 PM
roachnigga's Avatar
roachnigga
Default RE: OCC.../TURBO TIMER....??
All over this DF has OCC installs, make ya own OCC, even $20 OCC's. As far as TT's it doesnt matter if its stock or modified. it'll all work the same
Old Sep 1, 2004 | 12:47 PM
dustyloins's Avatar
dustyloins
Hall of Fame Member
The one most of us use is talked about on several threads in this section, just scan back a page or two...
IMO, a tubo-timer is something that is "nice to have" but hardly necessary. If you've driven your card hard enough for it to require a cool down period, you can just let the engine idle for the period specified in the owners manual.
Yeah, I'm "cheap"!!!![sm=smiley36.gif]
Old Sep 1, 2004 | 02:13 PM
lrl1990's Avatar
lrl1990
What is even considered driving it hard. Running it around a road course or what.
Old Sep 1, 2004 | 02:27 PM
dustyloins's Avatar
dustyloins
Hall of Fame Member
[sm=icon_rtfm.gif]
Yea!!!! I finally got to use that smiley!!!!!!! (joking)
I make it a habit to let my engine idle until the fan stops running (you can hear it). I also pop my hood open when I get home in the afternoon since it's usually close to 100 degrees outside by then and the engine compartment is really, really hot. I keep the coolant bottle filled as well.
BTW, anybody see that heatshield at www.modernperformance.com for the plug wires and the coil pack?
Old Sep 1, 2004 | 02:34 PM
roachnigga's Avatar
roachnigga
Aint that smiley Icon Geat!!
Old Sep 1, 2004 | 03:11 PM
lrl1990's Avatar
lrl1990
I know I should read the manual but I'm just to damn LAZY LOL hehehehehe. BTW, since I'm lazy how far is the coolant suppose to be up, is it suppose to be up to the full line when on a cold engine.
Old Sep 1, 2004 | 03:13 PM
dustyloins's Avatar
dustyloins
Hall of Fame Member
No, only on a "hot" engine.
Old Sep 1, 2004 | 03:40 PM
lrl1990's Avatar
lrl1990
Good, I looked in there once and got kinda worried thanks
Old Sep 2, 2004 | 03:31 AM
PSI Chick's Avatar
PSI Chick
i have the blitz tt. it's nice because it reads the tach wire and decides for me if the car needs a cool down period. it sets the time dependant on how long the car was driven, and how long i stayed above a certain rpm (which you set). i got it from exhaustdepot.net, and it comes with a harness and installation guide on cd.
i have the greddy catch can. i only have to empty it about every 3 months, much easier than the $20 one. i coughed up the extra cash for a real one
the coil pack heat shield...i have the one from bdj, they had it first and modern copied it from them. imo, the bdj one is a lot nicer, as it allows for more air flow to the turbo. this is especially important if you have the dc strut tower brace, as that blocks a lot of the air from getting back there. i also sloved this problem with the larger scoops in my hood, so i've been ok so far.
