Nitrous, Super Chargers, & Turbos All charged talk about going, and going FAST!
3.5L V6
Old Oct 27, 2004 | 07:37 PM
nickoman01's Avatar
nickoman01
The Only Elite DF Member
Default 3.5L V6
can u do any really big preformance mods to teh 3.5L V6. is there a supercharger or turbo for it.
Old Oct 28, 2004 | 02:02 PM
BadStratRT's Avatar
BadStratRT
The Forum Tyrant
Default RE: 3.5L V6
in what?
Old Oct 28, 2004 | 07:01 PM
moparturd's Avatar
moparturd
Default RE: 3.5L V6
I've seen one homemade turbo system that a guy did, but it wasn't terribly impressive.
Old Nov 1, 2004 | 07:14 PM
nickoman01's Avatar
nickoman01
Default RE: 3.5L V6
just in a general LH platform car such as a 300m or a LHS
Old Nov 1, 2004 | 09:52 PM
BadStratRT's Avatar
BadStratRT
The Forum Tyrant
Default RE: 3.5L V6
well, you can buy a side mount for just about anything..but there are alot of other upgrades you have to do.
Old Nov 2, 2004 | 12:22 AM
nickoman01's Avatar
nickoman01
Default RE: 3.5L V6
really like what. would i ahve enough room in the engine bay. what else is required to make ti function properly
Old Nov 2, 2004 | 02:02 AM
BadStratRT's Avatar
BadStratRT
The Forum Tyrant
Default RE: 3.5L V6
well, adding forced induction to a stock motor forces alot more air into it, so it wil run very lean so usually you have to run a higher volume fuel pump, and bigger injectors. you would also need to have your computer modified to accept the new flow of fuel and air. also, while its not essential, you will have more gains if you improve on the exhaust, because all of that intake flow ahs to go somewhere.
Old Nov 2, 2004 | 03:18 AM
nickoman01's Avatar
nickoman01
Default RE: 3.5L V6
wow tahts sounds like alot of work and expenses. how much of a hp gainw ould i get from simply putting in new spark plugs a cold air intake and a new exhaust system.
Old Nov 2, 2004 | 12:40 PM
BadStratRT's Avatar
BadStratRT
The Forum Tyrant
Default RE: 3.5L V6
its hard to say really..depends on how much exhaust work you did. it would also depend on how good the CAI is, and how restrictive your stock intake setup is. as for the plugs...on a normal car, putting expensive plugs in the motor will bring no more than very minor gains.
Old Dec 4, 2005 | 01:51 AM
97 3.5 Intrepid's Avatar
97 3.5 Intrepid
Default RE: 3.5L V6
nickoman01, why do you want that for an engine you don't even have in your car? Are you planning to upgrade to a 3.5L or something?
