Ramcharger, Trailduster & Power Wagon Grrrr!! Tough Trucks! The Dodge Ramcharger and Plymouth Trailduster were full size SUV's that had good looks and brute strength. The Dodge Power Wagon was comparable to them in toughness, but came in pickup truck form only.
1988 ramcharger fuel pump assembly
Old Aug 1, 2018 | 01:19 PM
HD_REN's Avatar
HD_REN
Default 1988 ramcharger fuel pump assembly
Hey y’all I’m trying to find a replacement for the fuel pump assembly in the tank of my 1988 ramcharger and nobody seems to have one except for the replacement pump itself. The plastic where the plugs are basically cracked/crumbled when I was pulling tank to replace the pump. Is there anywhere I can get the whole assembly? Your help is much appreciated.
Old Aug 2, 2018 | 07:43 AM
Carb? Or fuel injected???? I see mechanical fuel pumps and such, but, no one seems to have the sending unit....
Old Aug 2, 2018 | 09:40 AM
ZEN357's Avatar
ZEN357
Hope this helps you...
https://www.jegs.com/c/Fuel-Carbs-In...29838&sbv=true
Old Aug 2, 2018 | 08:22 PM
Moparite's Avatar
Moparite
He needs the whole thing housing and all. They stop making these for some reason. Seen a few threads about adapting a newer style to fit. Not sure if it was here but if i see anything about it i'll let you know.
Old Aug 3, 2018 | 09:17 AM
HD_REN's Avatar
HD_REN
its fuel injected TBI
Old Aug 3, 2018 | 09:20 AM
HD_REN's Avatar
HD_REN
Originally Posted by ZEN357
thanks but I’m looking for the whole unit in the tank including the fuel level sending unit
Old Aug 3, 2018 | 09:27 AM
HD_REN's Avatar
HD_REN
thank you!!
Old Aug 3, 2018 | 08:08 PM
Moparite's Avatar
Moparite
I found these but not sure if it will help. I know i seen something else on this but don't remember where. The oem part # is 5217863 if that helps you.
https://www.********.com/threads/how...gassers.75693/
https://ramchargercentral.com/vehicl...dge-w250-w360/
Old Dec 23, 2018 | 07:12 PM
Banjoman1's Avatar
Banjoman1
Try: http://tristarrradiator.com/
This guy rebuilt my 1988 fuel pump assembly like new! He has glues, epoxies and and everything to make them better than new!
