2nd Gen Ram Tech1994-2001 Rams: This section is for TECHNICAL discussions only, that involve the 1994 through 2001 Rams. For any non-tech discussions, please direct your attention to the "General discussion/NON-tech" sub sections.
1996 2500 dodge ram 360. Got wrapped off manifold. So after investgation one spark cut in half. So I had the bright idea to tune it up cap,rotor and such. Well in the process snapped rotor cap screws. Got #1 tdc and marked distributor and replaced with new one. Now she just cranks and cranks. Rotor is facing #1 cylinder and distributor. in same spot. I check only one wire and has spark. Had to stop down pouring. What could it be? Any help appreciated.
I replaced the distributor with all new parts. Now the engine keeps cranking (it won't start). I checked the spark plugs and I do have spark. Did I explain it any better.
