Can't Turn Motor Over By Hand??
Im trying to turn my motor over by hand so I can bolt the flywheel to the converter, but my motor wont turn? It turned over by hand to get the bolts off a few days ago and now it wont. I have no spark plugs out, im going to pull the plugs and spray the cylinders with rust penatrator to see if that helps. Any other ideas would be great.
Pull the plugs and try it. If you had a water leak, and it's sat around for awhile and there's anti freeze in the oil...Hello rebuild.
Pulled the plugs and sprayed with rust penatrator, I can't turn it the other way because the center bolt loosens, I have been using a breaker bar to turn it. Im going to let it soak a little bit, but im wondering why that center bolt is coming out, or why when I tighten it it don't turn the motor
The TC should spin relitively easy.
Dave
