4.7 to 5.9 swap. SEARCHED!
Old 09-06-2011, 05:29 PM
nonameuser's Avatar
nonameuser
nonameuser is offline
Question 4.7 to 5.9 swap. SEARCHED!
Hey everyone. Ill start off by saying that I HAVE searched this forum for information. Basically what happened was the heater core line busted at the T and leaked ALL of the coolant out. There was never any steam or any sign of overheating.. Anyway, the temp gauge never went hot, but the engine got so hot it shut off on me. After looking around a bit I had found the problem. After it was all fixed, the engine cranked but ran like hell. I did a compression test and had 0 compression on #1, 90 psi on 2, 160 on 4 and 100-110 on the rest. I pulled the valve cover and saw one of the valves on #1 was not closing. The rocker is as loose as it can be.
Now, on to my real concern. I had a 2001 ram 5.9 that I had put a lot into. Had performer rpm heads, cam, TB, intake mani, headers, custom flash, etc,etc. I totalled the truck a couple years back and kept the entire drive line. motor, accessories, trans, harness, computer. I know the 02 rams cam with the 5.9 and the 4.7. Im trying to figure out what needs to be done to put this engine in. Almost all of the treads i have found about this are just telling people to either replace with another 4.7 or to get a 5.7. I have this engine sitting here begging to be put it. I dont want to do a hemi or replace the 4.7. The 4.7 pcm thats in the truck is the 3 connector type.
Here is the list of things I have found that need to be changed:
trans
wiring (will the old wire harness and pcm plug into what i have or do i have to rewire things?)
pcm
motor mounts
pcm flash to make VINs match if i dont want abs lights.
Im not sure about the trans crossmember or driveshaft. I also read somewhere that i might need a different oil pan. Should i use the 4.7 or 5.9 accessories? are there any problems making PS, AC, Alt, ect work?
If anyone has a link on this information or just any info that can help me pull this off would be greatly appreciated.
Thanks!
Robert Wood (07-11-2019)
Old 09-06-2011, 08:42 PM
jasonw's Avatar
jasonw
jasonw is offline
Site Moderator
Welcome to DF.
First, before anything else, please read this:
https://dodgeforum.com/forum/dodge-ra...s-section.html
I will move you to the 2nd Gen Ram section (1994-2001 Rams).
Old 09-06-2011, 09:09 PM
nonameuser's Avatar
nonameuser
Sorry if I posted in the wrong place. The truck is a 2002 with a 4.7. I have an engine from a 2001 I would like to use.
Old 09-06-2011, 10:10 PM
dodge dude94's Avatar
dodge dude94
dodge dude94 is offline
Banned Goober Smoocher
Find a 2002 Ram 1500 that had the 5.9 in it.
If the engine isn't yanked, start looking at what you might need.
Motor mounts for sure, wire harnesses MIGHT be different. Engine didn't change, but the engine BAY did, greatly.
Good luck and welcome to DF!
Old 09-07-2011, 01:26 PM
nonameuser's Avatar
nonameuser
I have searched all of my local yards... Not a single 02 ram with a 5.9 in it.. it really sucks too because I'm gonna have to find parts and have them shipped to me if it turns out I can pull this off. If anyone knows what all I will need and also has access to a 02 5.9 donar truck, I would gladly paypal for time/effort to pull and ship parts.
No one knows of a thread with this info?
Old 09-07-2011, 01:40 PM
zman17's Avatar
zman17
zman17 is offline
Retired Moderator - RIP
Your going to have to find an 02 2500 if you want something that has a 360 in it.
Old 09-08-2011, 09:11 AM
jasonw's Avatar
jasonw
jasonw is offline
Site Moderator
Not necessarily. They offered the 5.9L V8 all the way up through 2003 in the 1500s. The HEMI was an upgrade option.
Old 09-08-2011, 09:16 AM
zman17's Avatar
zman17
zman17 is offline
Yea I know, I realized that a few hours after my post.
Sorry OP.
Old 09-11-2011, 10:08 AM
ryanek9freak's Avatar
ryanek9freak
ryanek9freak is offline
Not to hijack, but I've been thinking of doing the exact same thing, as my 4.7 has 225,000 miles and it's on it's last leg. Finding actual engine wont be hard, as in 2002, you could also use a 5.9 out of a durango or dakota, but actually mounting it IN there is where it would get tricky.
I share the OP's frustration, trying to find an '02 1500 with a factory 5.9 in a salvage yard is like looking for a needle in a stack of needles.
I used to work for a Dodge dealership, and I tried sourcing parts, and unfortunately, dodge has discontinued the engine mounts for the 2002 Ram 1500 with the 5.9 Option. I've been searching high and low for a set of used ones.
I suppose you could always make them if you had to.
As far as the PCM/ Harness goes, the harness for the 5.9, as well as the 4.7 are self contained and do not integrate with the vehicle harness, so as long as you got the harness/PCM intact, it would just be a simple swap. The 4.7 and 5.9 share the same transmission for THAT year, and that year alone, you just have to change the bell housing, so as far as the PCM goes, you wont have to change anything. It would just have to be reprogrammed for the VIN on your truck, otherwise you get ABS/Brake lights and annoying beeps everytime you start the truck. Most snap-on scan tools have the ability to program Dodge PCM's now, I know, I did it on mine when I replace the computer, takes about 5 minutes.
My dream configuration is the factory 5.9, built just a little with mild cams/bigger injectors, etc, with a 6 speed NV3550 behind it. Would make for a sweet little 1500.
Old 09-13-2011, 12:15 PM
nonameuser's Avatar
nonameuser
rRyanek, are you sure about the trans being the same aside from the bellhousing? they dont look to be the same to me. and it is extremely difficult to find info on this. There are NO 02s with a 5.9 i have been able to find.. Can someone please chim in here? I have read articles where people say they have done it. So someone has to have more info...
Quick Reply: 4.7 to 5.9 swap. SEARCHED!
