cummins maybe a possible swap
Old 08-02-2012, 02:08 AM
Goatley's Avatar
Goatley
Goatley is offline
Default cummins maybe a possible swap
I have been thinking about it for a while instead of building the turbo motor just doing a cummins swap. Good power tons of torque and well better gas mileage. (so Ive heard)
Im not sure which one to go with so I do believe I would like to go with the easier one to swap in seeing as I will try to do it all myself and Im no mechanic, but will have one close.
The main reason is there is a issue with my motor and its in a bad spot right now and my rebuild will be high so that s why the swap came up what do yall think?
Rebuild a 318 or cummins swap? And which one?
Old 08-02-2012, 07:55 AM
Received 3,256 Likes on 3,003 Posts
It is cheaper and easier to just sell your truck, and buy one with a cummins already in it... Not a trivial undertaking. Not to mention that the diesel weighs quite a bit more, and that will take a toll on the front end... it really isn't designed to deal with that much weight.
If you want to do the swap anyway..... getting a wrecked truck with the engine you want, that is the same OBD version that you have would make it easiest. Finding one is the fun part...
Old 08-02-2012, 10:22 AM
Goatley's Avatar
Goatley
Goatley is offline
my brother is helping me put the other motor in today.
Old 08-02-2012, 04:49 PM
Wh1t3NuKle's Avatar
Wh1t3NuKle
Wh1t3NuKle is offline
So it's not a "maybe" anymore. You already found one.
Old 05-17-2024, 02:45 PM
xackkkkkkk's Avatar
xackkkkkkk
xackkkkkkk is offline
Can I get an update I want to do it to my dodge ram100
Old 05-17-2024, 03:01 PM
12 year old thread. I wouldn't hold my breath.
Old 05-18-2024, 06:44 AM
Moparite's Avatar
Moparite
Moparite is offline
Goatley hasn't been here since 2014.
Quick Reply: cummins maybe a possible swap
