Electrical Problem
![Unhappy](https://dodgeforum.com/forum/images/icons/icon9.gif)
Hello
I have a 2002 Dodge Dakota.
Two issues.
First: When it is dark and I need to turn on lights. I have a problem. If the door is ajar and I am in drive my lights start flashing, all lights. But it will not do this in the daylight.
Second: As above when my gas gauge shows I need fuel it does the same. Lights start flashing. All lights
Please help
Kevin
Two issues.
Please help
Kevin
the company that installed my security system did a hack job on my truck I have tried many times to fix all the hacked into wires an mixed up mess they gave me never again will I have a shop install a stereo or security system in any auto.
The system box dropped down one day and I stepped on it and ripped half the wires out of it took me forever to fix![Icon Rant](https://dodgeforum.com/forum/images/smilies/icon_rant.gif)
What a friging mess my wires are
hey 98dakaz im sorry you feel that way one bad apple should not spoil the bunch but at the same time you said YOU have tried many times to fix it and it sounds like it took you a while to succeed at it if you would have taken it to a stereo shop they may have fixed it in an hour and only charged you $50. Bearfroese, i would recommend taking it to a electronics shop if you feel that you are not knowledgeable enough on the aftermarket alarm install to tackle the problem yourself. too much can go wrong and cost you more than the shop will cost you. just my $0.02 worth. ( i fix these kind of problems almost daily!)
00DakDan is your best bet for this
Without being at your truck and looking at it I could never help you on this forum as I said my wires are a mixed up mess also.
He will need all the info you can give him like do you have a stereo is it stock OEM or aftermarket what kind of alarm system do you have any other add on’s that need wiring
Can you supply any pictures up under the dash of the wiring?
