2000 5.9 doesn't want to shift out of first
GFs 2000 Durango, 5.9 Auto with 4WD, doesn't want to shift out of first. It was low on fluid, and I topped it off with about a quart, but no change in symptoms. She says it seems to get worse as it heats up. I drove it and tried manually shifting 1,2,D and it wouldn't shift then either. What I noticed was that it would shift, but only after it got to about 25 or so MPH and about 3000 RPM, and only when I backed off the gas for a few seconds. Neither one us can afford a rebuild, does this sound like something related to the sensors? I worked as a mechanic for about 8 years, but know nothing about transmissions. Please tell me I can do something with this other than buy her a new car
Thanks!
Thanks!
Yep, that sounds a lot like an electronics problem.
Disconnect the 8 pin connector on the trans. Drivers side, about halfway back. Plugs straight down into the top of the valve body. (on the outside of the trans.) With it unplugged, go for a drive. There will be ZERO automatic function, so, start in first, and upshift/downshift when appropriate. There will be no O/D, or TCC either. Three gears is all ya get. If it shifts into the correct gear when you tell it to, up and down, it's just electronics. Can fix it for around 110 bucks, plus fluid, and filter kit. Just get the 'heavy duty' governor solenoid/pressure sensor kit from ebay. Lots of folks sell 'em.
OK. I pulled the TRANS relay, and for good measure the 20A TRANS fuse, both in the PDC. Driving it I didn't feel a shift from 1st to 2nd, but there was certainly a shift into 3rd gear each time through, and at 30mph the RPM was around 1500. I ran it until it was good and hot, and it made the shift into 3rd every time. It is entirely possible that it is actually starting in 2nd gear and not first doing this manually, because her linkage is slightly mis-adjusted (the indicator shows between N and D when it is actually in D, etc). So you think this indicates that it would be the governor solenoid/pressure sensor? I found several of those on ebay, as well as a video on how to replace it.
If you aren't getting first gear, need to find out why. The indicator in the dash isn't the most accurate thing in the world..... and can be adjusted, but, you need to make sure the linkage is actually doing it's job, and putting the trans all the way down into first gear. (you can check that with the engine off, wheels blocked..... safer that way..... )
If you aren't getting first, even with everything else working right, then changing the electronics probably won't help.
