T case noise
Old 01-15-2018, 09:23 AM
jlake4130's Avatar
jlake4130
jlake4130 is offline
Default T case noise
01 ram 1500 4x4
My t case is making this weird howling noise when driving (i can only here it when going slow). The video was made with the rear tires off the ground and spinning the rear tires by hand. Fluid is full and clean. what do you guys think?
Old 01-15-2018, 11:38 AM
Ramman18's Avatar
Ramman18
Ramman18 is offline
Screw the noise; where'd you get that custom crossmember and control arms?
Old 01-15-2018, 12:24 PM
jlake4130's Avatar
jlake4130
Lol, i made them.
Old 01-15-2018, 01:37 PM
Ramman18's Avatar
Ramman18
Ramman18 is offline
Ah. Shouldn't a squeak be a dry seal?
Old 01-15-2018, 01:46 PM
jlake4130's Avatar
jlake4130
maybe. im thinking more or the pads on the shift forks wore off and are rubbing?? crazy sound for sure
Old 01-15-2018, 06:46 PM
2bit's Avatar
2bit
2bit is offline
Take the drive shaft off and remove the tailshaft housing. There is a snap ring on the output shaft that breaks or comes out of it's groove.
http://www.drivetrain.com/parts_cata...ase_saver.html
Old 01-16-2018, 07:50 AM
jlake4130's Avatar
jlake4130
2bit, thanks but i already have one installed. Cheap insurance though and i recommend it to others for sure!
Old 01-16-2018, 10:54 AM
Ramman18's Avatar
Ramman18
Ramman18 is offline
Could it be the ujoint at the yoke?
Old 01-16-2018, 01:59 PM
jlake4130's Avatar
jlake4130
tonight after work im going to pull the rear drive shaft and give it a try.
Quick Reply: T case noise
