Dodge Journey Dodge Journey forum for discussion on the popular Dodge Crossover and CUV.
ambient air tempt
Old 02-10-2018, 01:28 AM
DodgeJames2013's Avatar
DodgeJames2013
DodgeJames2013 is offline
Default ambient air tempt
anybody know where the ambient air temperature is located???
Old 02-10-2018, 07:43 AM
jkeaton is offline
In front of the radiator attached to the radiator support.
Old 02-16-2018, 02:50 PM
Jason Holtzberger's Avatar
Jason Holtzberger
Jason Holtzberger is offline
Any diagrams for this, I found my wife'shanging and can not find where it belongs.
Old 02-16-2018, 02:51 PM
jkeaton is offline
Just find a spot with good air flow and use a wire tie to secure it.
Old 02-16-2018, 03:15 PM
Jason Holtzberger
Great thank you very much. Thought about that just wanted to be sure that would do the trick.
Old 02-16-2018, 03:31 PM
Jason Holtzberger
Also I am seeing after getting in the car it is saying external temp is -40. Does this mean the sensor is bad? I did tie it to the gill so it got plenty of air flow as suggested, Any way to reset the CEL or this reading without going to the shop?
Old 02-16-2018, 05:01 PM
jkeaton is offline
Any auto parts store can reset the code. Probably a bad sensor, connector or wiring.
Old 02-16-2018, 10:25 PM
primem's Avatar
primem
primem is offline
when the circuit is open, the display reads -40............check the wires first before replacing a sensor.
-uplugging the sensor should set a circuit high code and cause it to read -40.
-Shorting the wires together should set a circuit low code and cause the high code to do stored.
-one wire should have a 5volt reference voltage.
if those 3 thing occur...the wiring is good, replace the sensor
Quick Reply: ambient air tempt
